Old 01-28-2010, 06:08 PM   #1
aws68
So I thought I scored some buddy buckets...
But it turns out that the brackets don't line up in my cab, and after looking around here I realized that they must have come out of a Dodge van or truck. There is no center bracket, but the sides of the frame look different that some others I found here--the tube frame on mine is round on the ends, while some other Dodge versions are flat:
http://67-72chevytrucks.com/vboard/s...d.php?t=252608
I paid $660 on ebay, which of course seemed like a good deal at the time since they are in decent shape.
Is there any way to tell for sure that these seats came out of a Dodge? Since they were advertised as coming out of a 67-68 Chevy, I'm working with the seller on getting a partial refund. What do you guys think is a fair price? In the threads I've found, guys have paid anywhere from $75 to $150 for the Dodge seats.
aws68 is offline   Reply With Quote
Old 01-28-2010, 07:30 PM   #2
wancosc356
I Like Mine With No Shine!
wancosc356's Avatar
Re: So I thought I scored some buddy buckets...
Those are for sure dodge seats. The frame, foam and covers are different. I have seen plenty of guys using the dodges in their chevys though. Most people can't tell the difference.
Did you pay $660 shipped?
I would say that they are still worth $250-$500 for the setup.
Just my $0.02
Michael
1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day)
2006 GMC Sierra Crew Cab 4x4
1969 Lincoln Continental Coupe Project FOR SALE
http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17
1981 Honda CM400 C Bobber SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=384152
wancosc356 is offline   Reply With Quote
Old 01-28-2010, 07:59 PM   #3
aws68
Thanks, Michael. Unfortunately, I paid $810 total, $660 plus another $150 for shipping. The only problem I see is that it might be a bit tricky to attach different end brackets, as the frame isn't flat on the ends.
Old 01-28-2010, 08:09 PM   #4
wancosc356
wancosc356's Avatar
No problem. Oh ok. Well here are my two thoughts:
1. Tell the seller that you are not happy with the fact that they are not GM seats like they were advertised as. I would ask for all of my money back and return the seats. Turn around and find the couple sets that are in the for sale section and should be able to get a set of GM ones shipped for less. If the sellers doesn't agree with you, you can file a dispute with ebay that they were not what they were stated to be.
2. If you don't wanna deal with it and like the seats and are happy with your purchase, figure out a way to use the seats. Find the other guys on here that use dodge ones and see what they say about making them work. I would still ask for a partial refund (half or more of the total you paid) due to them not being what he said they were.
Michael
Old 01-28-2010, 08:12 PM   #5
sdailey
The Few, The Proud
sdailey's Avatar
Contact member msgross, he has a set of Dodge buddy buckets that he's installing in his '68 and he had another member here make a set of cab mounting brackets that look like the original GM brackets and I believe mount in the cabs original holes.
I believe he gave $150 for his seats, but don't hold me to that.
Edit: Here's Mike's build thread. Go through it and you'll see his seats and the brackets that he had made.
http://67-72chevytrucks.com/vboard/s...d.php?t=242910
Shannon
sdailey is offline   Reply With Quote
Old 01-28-2010, 11:47 PM   #6
Fitz
But you did! They don't fit now but making them fit will take you only a half day to make a pattern, transfer it to some flat sheet, cut it out and either weld it or get someone to do it for you. Cut a piece of white card stock about 6 in wide and about an inch longer than the distance front to back between the mounting holes in your floor. Remove the carpet from your cab and place the seats where they should go to give the correct sitting position with the holes in the brackets the same distance from the mounting holes in your floor on both sides. Slip the card stock under your seat mounts and position the stock so it also covers the.holes in your floor with about 1/4 to 1/2 in overlap on each side of the holes. Punch an awl through the cardstock and into the mounting holes then run your mounting bolts and washers through the card and into the mounting holes in your cab floor to hold it in place. Do this on both ends of the seat. When both sides are done, make sure the seat is still correctly lined up and trace the outline of the bottom of the seat bracket on the card stock and mark the location of the mounting holes for the seat brackets. Now you have a card pattern for a plate which gets trimmed and welded to your seat brackets that absolutely fits your floor! If you drill out the holes marked on the card for the seat brackets you can bolt the plates to the brackets to hold them exactly aligned when they are welded. It's a very fiddly job but 20 bucks worth of 10 gauge plate saves the investment you have in your seats. Not to mention that there are new aftermarket covers for those seats...when you need them.
Fitz is offline   Reply With Quote
Old 01-29-2010, 01:44 PM   #7
aws68
Thanks for all the suggestions guys.
Old 02-03-2010, 09:46 PM   #8
my67chevytruck
Under Construction
my67chevytruck's Avatar
That is spendy for a set of dodge buddy buckets... I would say they are worth about 250.00 plus shipping . I would ask for a refund as they are not what they were stated to be. for 800.00 you will be able to get chevy buddy buckets with a frame that fits with no modification. That's my opinion however. best of luck with your decision.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 02-03-2010, 10:20 PM   #9
Sublvr72
Sublvr72's Avatar
bummer, I have a set of panel buckets for sale in the F/S section for $250
Sublvr72 is offline   Reply With Quote
Old 02-04-2010, 09:01 AM   #10
junkyardjohn
junkyardjohn's Avatar
DON'T YA JUST HATE IT WHEN SOMEONE ADVERTISES SOMETHING AS BEING RARE & DESIRABLE, & WINDS UP BEING AS RARE AS A MISHAPEN ROCK? WEATHER IT'S IGNORANCE OR JUST PLAIN GREED DOESN'T MATTER, YA BETTER KNOW WHAT YOU ARE SELLING. OTHERWISE IT'S FRAUD & THE SELLER OUGHT TO BE BANNED FOR LIFE FOR THIS PRACTICE. I THINK WE'VE ALL BEEN TAKEN THIS WAY (SOONER OR LATER) ON THE INTERNET. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 02-04-2010, 11:42 AM   #11
lpaine
lpaine's Avatar
Hey, JunkYard John, I have'nt seen you on here for ages, I was wondering what became of you. Good to see you back. Lew
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
Old 02-04-2010, 08:37 PM   #12
aws68
Thanks again for the replies. This gives me a good place to start working with the seller on a rebate amount.
Old 07-19-2010, 01:43 PM   #13
VA72C10
VA72C10
VA72C10's Avatar
you ever get this worked out through ebay?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 07-19-2010, 03:21 PM   #14
OhioDan
OhioDan's Avatar
I purchased a set of buckets that look just like yours. Same color and everything. Mine cost $100.00 . Had them recovered for $300.00 . Had to make a bracket to bolt on the end of the seat frame, as those are set up for a Dodge. Sorry to hear ya bought Dodge seats instead of Chevy seats. Apparently the seller didn't know what he was selling. I think I'd try and get my money back, and send him back his seats, unless he wants to sell them to you for $100.-$250? Here's mine after making the bracket to work, and recovering them.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 07-19-2010, 04:43 PM   #15
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
I just realized that this thread was almost 8 months old. I sure hope he got it worked out. That is a TON of money to spend on the wrong seats. This is a good reason to pay for everthing with Paypal. You can easily file a dispute and have a mediator work through it with you and the seller.
I have a perfect eBay feedback as a seller of 782. Part of that is because I do the right thing. Sometimes "STUFF" just happens and you have to make it right. I'm guessing that must have been a "buy it now" auction. Hard for the price to get up that high through an auction if it is not listed correctly. Hope it worked out and the seller did the right thing or you at least filed a complaint.
prostreetC-10 is offline   Reply With Quote
Old 07-19-2010, 04:53 PM   #16
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
The biggest problem with paying through pay pal is you still only have 3 months I believe to get it handled, which is better than nothing if you pay another way. Hopefully he got something worked out with the seller.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 07-20-2010, 09:21 AM   #17
prostreetC-10
My Carbon Footprint
This is true but You should know in 3 minutes if the part is right or not. It's not a good idea to just look at a part you have bought and assume it is right. Sellers on eBay make honest mistakes ALL THE TIME. This is why you have to check the part soon after receiving for reasons just like this. I hear what you are saying though DW. This is why it will ALWAYS be a "buyer beware" world. BTW....I have some ocean front property in AZ I'm gunna let go real cheap.
Old 07-22-2010, 05:59 PM   #18
aws68
eBay was no help on this one. I was in school at the time, so I had the seats shipped to my parents and didn't check them out until I got home for Christmas over a month later. eBay requires you to file a complaint within 45 days, which I didn't, so I was out of luck. The seller also preferred that I send him a check to avoid the PayPal charge, so I made a mistake there too. Chalk this one up to a few lessons learned, I suppose.
Old 07-22-2010, 06:03 PM   #19
aws68
I did forget to mention that after I complained to the seller, he did send me a check for $150, which was less than I asked for but a surprise nonetheless. And nice work with your seats OhioDan, they look great.
Old 07-22-2010, 09:45 PM   #20
OhioDan
OhioDan's Avatar
Thanx.
