Old 01-28-2010, 09:33 PM   #1
jmking9
jmking9's Avatar
Will 71-72 5 lug axles work in 70 rearend???
I'm wanting to convert my rearend to 5 lug. The rearend in my 70 is the wide version. My Q is will 5 lug axles out of a 71 or 72 fit without modification. I found a good deal on a 5 hole coil rear. My rear is a 3.73 posi, thats why I just want to swap axle shafts. Also will the Drums off the 71/72 fit once I change the shafts. Thanks for the input.
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 01-28-2010, 09:37 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Will 71-72 5 lug axles work in 70 rearend???
I think everything you stated is true I THINK
you can order new axles from ECE for under 300$
John
1999 Toyota Tacoma 4x4
Old 01-28-2010, 09:39 PM   #3
Hart_Rod
Hart_Rod's Avatar
Yes and yes...
Hart_Rod is offline   Reply With Quote
Old 01-28-2010, 10:51 PM   #4
jmking9
jmking9's Avatar
Thanks for the replies. Found this rearend out of a 72 that the guy is parting out(Blown Motor). Its a 3.08 open he thinks. He said he'd take 50 bucks for it. I pulled the drums off and they dont look worn much at all. He thought they were replaced a couple of years ago. I figured its worth the $ for the drums alone. Looks like i'll be picking it up sat.
1970 SWB Build
Old 01-28-2010, 10:53 PM   #5
oldblue1968chevy
what should I look for in a rearend? going to look at a 5 lug coil from a 402BB tomorow..
John
Old 01-28-2010, 11:21 PM   #6
Fitz
ECE does indeed have 5 lug 30 spline axles for 63-72 12 bolt rears...$279.00/pair. If you're already running a 3.73 posi thats a great combo...later, when you get tired of drum brake fade, the rear calipers from a late 70's cadillac seville will fit your housing, and they have the emergency brake built into them... CPP has the rotors and caliper brackets which will fit those new 5 lug axles.
Another plus is you'll be running a standard 5x5 lug pattern; everybody and his brother sells wheels that will fit that setup!.
Fitz is offline   Reply With Quote
Old 01-29-2010, 08:13 AM   #7
c10crazy
Like a Rock!
c10crazy's Avatar
Just curious, how "wide" is your version???
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 01-29-2010, 08:14 AM   #8
c10crazy
Like a Rock!
c10crazy's Avatar
One more question on this subject, not to hijack- can he use any axles from later years like 73' and up??
69 LWB
