Old 01-28-2010, 09:40 PM   #1
Beatcoaster
69 Fleetside
Beatcoaster's Avatar
Vortec heads, will these headers work?
Getting a new engine with vortec heads and am trying to find some reasonably priced headers that will work with them. Will these?
http://www.jegs.com/i/Hedman/500/69890/10002/-1#
Beatcoaster is offline   Reply With Quote
Old 01-28-2010, 10:27 PM   #2
AusTx68
AusTx68's Avatar
Re: Vortec heads, will these headers work?
I just bolted up a set of Patriot Clipsters on my Vortec 383 today. They are a few dollars more.
http://www.summitracing.com/parts/PTE-H8021-1/
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 01-28-2010, 10:32 PM   #3
Beatcoaster
69 Fleetside
Looks like somebody got the same BluePrint 383 I'm ordering as well!...Mind if I ask what was missing from the complete package that you needed also? flexplate obviously - but things like dipstick/pvc/breathers/etc?? Thanks!
Old 01-28-2010, 10:59 PM   #4
AusTx68
AusTx68's Avatar
The main components I had to add were flywheel and starter. Almost everything above the intake is supplied(breathers, pvc, ignition). All that was missing was the water neck and thermostat. Tomorrow my billet pulleys and chrome alternator come in
Old 01-28-2010, 11:05 PM   #5
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I understand that all the small block headers are the same
correct me if I'm wrong because I bought a set of vortecs to put on my 327 and am looking for an intake....I was told I could reuse my headers??
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 01-28-2010, 11:15 PM   #6
AusTx68
AusTx68's Avatar
That's my understanding too. I didn't specify Vortec when looking for headers.
Old 01-29-2010, 07:06 AM   #7
Blazer1970
Blazer1970's Avatar
Small block heads are not all the same as far as the exhaust ports and bolt pattern are concerned. But - Vortec heads and the original heads that came on these trucks are exactly the same (exhaust ports and bolt pattern) so you can buy headers for a '67 - '72 with a small block and don't even worry that you have swapped the heads.
Blazer1970 is offline   Reply With Quote
Old 01-29-2010, 08:57 AM   #8
mrein3
mrein3's Avatar
I guess that means stock exhaust manifolds would bolt up and work too. Eh?
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 01-29-2010, 10:13 AM   #9
Sammy
Yes, I have stock manifolds. They bolt up and work fine.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 01-29-2010, 10:31 AM   #10
Hottrucks
Hottrucks's Avatar
sorry to highjack but what are you guys using for intakes??? I have heard that the marine 4 barrel intake are good ....is there a stock 4 barrel intake for them??
Old 01-29-2010, 11:03 AM   #11
Sinister
Between Trucks...
Sinister's Avatar
Don't believe there was a factory 4 barrel intake, Vortec engines were injected, but check out this link: http://www.hotrodders.com/forum/cast...bl-171865.html
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 01-29-2010, 12:35 PM   #12
Hottrucks
Hottrucks's Avatar
like I thought it was for industial and marine use??? Hmmm guess I'll have to look around the boat guys...guess they flow well..just need to keep my eyes open for a use one or an after market...I like the air gaps ......
Old 01-29-2010, 02:50 PM   #13
Beatcoaster
69 Fleetside
I think they were all TBI from the factory. Edelbrock's basic performer vortec intake is 175 from Jegs which isn't bad...
Old 01-29-2010, 10:41 PM   #14
big mike71
big mike71's Avatar
I have the same headers on mine they work fine.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
