Old 01-28-2010, 09:42 PM   #1
3r!c84
Badass
3r!c84's Avatar
lower ball joints
i need to replace them. any kinda way of doing so?
already got them,35$ each
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 01-28-2010, 09:56 PM   #2
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
Re: lower ball joints
It's a job that requires the right tools. If you have never removed the front spindles on a 2 wheel drive there are some tricks to it. YOu must know what you are doing. The spring can come out of there with enough force to do some serious bodily damage. Check out this link. It will show you how it's done. You will need a ball joint press. You can get one at harbor freight for around $40. Good luck. It's a good learning experience.
http://www.instructables.com/id/Repl...94-Chevy-1500/
Mr.Chevy4x4 is offline   Reply With Quote
Old 01-28-2010, 10:00 PM   #3
3r!c84
Badass
3r!c84's Avatar
i know how to do all that.im brining it to school tomrow and see if the teacher will let me press the ball joints in.(we just did it on a little ranger a week ago) but i just wanna know if theres a trick too it
-00 Saturn 5spd
1/4:13:90
Old 01-28-2010, 10:03 PM   #4
Mr.Chevy4x4
The ball joint press from harbor freight works well. It's like a big c-clamp with adapters that make pressing it in or out fairly easy.
Old 01-28-2010, 10:10 PM   #5
3r!c84
Badass
3r!c84's Avatar
yeah but i dont like going in there,im like a kid in a candy store haha go in for one thing and come out with 2 hand fulls
-00 Saturn 5spd
1/4:13:90
Old 01-28-2010, 10:24 PM   #6
thehitchmaster
thehitchmaster's Avatar
mr chevy is right. you'll save tons of time and headache getting a press. thats just my opinion.
thehitchmaster is offline   Reply With Quote
Old 01-29-2010, 11:35 AM   #7
oldschool18
oldschool18's Avatar
never used a press just a hammer
oldschool18 is offline   Reply With Quote
Old 01-29-2010, 11:47 AM   #8
nlped
nlped's Avatar
I wouldn't recommend using a hammer to install the LBJ's, but they work great removing the old ones.
A ball joint press is definitely the easiest and safest way to install the new LBJ's while the LCA is still in the truck. You don't risk bending or warping the ball joint hole. When I did my frontend, I actually replaced the LBJ's with the control arms out of the truck, because I was painting and replacing all the other as sundry bushings. I used a shop press, but it's the same premise as the BJ press you would be using.
Good Luck!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 01-29-2010, 11:50 AM   #9
silvereagle07
silvereagle07's Avatar
I"ve done both methods and by far the ball joint press is the way to go. The press is on sale at Harbor Freight for a mere $32. Believe me it's less stressful and easy. You don't run as much risk warping the lower control arm like nlped said.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 01-29-2010, 12:04 PM   #10
oldschool18
And it depends on the truck, ive wacked a ball joint once and it fell out and ive hit them 10 times. if you put a floor jack right under it and wont bounce. My father has a garage and has been in business for over 35 years and I have never seen one warp from smacking it with a hammer. and you dont need a press to put one in just take a socket that fits the outside edge of the ball joint and a floor jack and jack it up use the weight of the truck. but then again I learned from my dad who prob learned from some old head years ago before they had ball joint press's..............or you can go buy a press
Old 01-29-2010, 01:55 PM   #11
OJOE
Crew Cut
OJOE's Avatar
x2
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 01-29-2010, 02:04 PM   #12
Slonaker
Insert Witty Text Here
Slonaker's Avatar
You can borrow the presses from most auto parts stores. They do work very well.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 01-29-2010, 04:25 PM   #13
joe231
joe231's Avatar
yeah I have done it this way as well, but I used a bottle jack from the under side and lightly tapped on the lower control arm to help it in.
CHEVY ONLY
Old 01-29-2010, 04:49 PM   #14
MobSled
MobSled's Avatar
Autozone+credit card=balljoint press with adapters. They rent it out for free to you and you can keep it for 48hrs. They do charge your card around 250 bucks but if you bring it back unharmed and on time you'll get that 250 put back on your cc.
Did I mention their bj press comes with different size adapters, makes the job 100 gtimes easier without a hammer or worries of warping the holes and its free.
MobSled is offline   Reply With Quote
Old 01-29-2010, 05:02 PM   #15
joe231
joe231's Avatar
last time I rented from autozone it was well under $100
CHEVY ONLY
Old 01-29-2010, 09:52 PM   #16
MobSled
MobSled's Avatar
Yeah tell me about it...they do have the simple bj press with onle one size adapter which is 100 bucks. I`m going to assume your gonna have to struggle with it a bit or you can get the better version with 6 different sized adapters which is 250. Either way they charge the cc but refund it when you bring it back. Or maybe those Aholes just upped the prices like everybody else.
Old 01-29-2010, 10:17 PM   #17
MR .T
MR .T's Avatar
Ive never used or seen someone use a press. 4lb hammer is the way to go, Iknow a few flat rate Ford mechanics who use this method daily. Its faster and nothing breaks.
MR .T is offline   Reply With Quote
Old 01-29-2010, 11:04 PM   #18
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
the harbor freight press is nice to have around tho ive used it for ball joints a couple of times on different cars... more than paid for itself
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 02-05-2010, 08:24 PM   #19
3r!c84
Badass
3r!c84's Avatar
could i pull it in with a a big socket on the top side of the balljoint and tighten the nut on the balljoint down there for pulling it into the lca?
-00 Saturn 5spd
1/4:13:90
Old 02-05-2010, 09:10 PM   #20
old Rusty C10
you would have to have a pretty large drive socket to get the stud part of the ball joint into the hole .. Im wonder if you could make a press out of a large C Clamp , some flat stock and some small sections of pipe?
Bob
I hate cancer!!
Old 02-05-2010, 09:37 PM   #21
3r!c84
Badass
3r!c84's Avatar
i got big sockets like that.so i was thinking i could find a way to jerryrig somthing up
-00 Saturn 5spd
1/4:13:90
