coil springs not sitting flush
I have a problem with my springs. The lower control arm has the end where your suppose to align the end of the spring with. If I do that the top is about 90 degrees off from sitting flush as they are kind oval.
I can turn the spring counterclockwise which does not put the bottom on top of the lip as it is going the opposite direction. Is this OK to do? What are everyones thoughts on this? It will let the top sit flush and the bottom is still flush it is ust not at the end where the indentation stops ![]() ![]() |
![]() Join Date: Feb 2003
Re: coil springs not sitting flush
im installing mine tomorrow. will give you update then..
1971 K5 CST Blazer 1951 -3100 short bed 4sp 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
Have the springs been cut?
BOHICA
Not sure if it matters, but is there a right and left side, could they be mixed up?
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig! |
r they the right springs? if new and they dont fit return them
They are ECE 2" drop springs. If I turn the top to fit properly in the top so it fits the oval portion the bottom is 2" counter clockwise from being at the end of the control arm indention.
both springs appear to be identical. I can switch out the springs and both are ending in the same spot when fitted on top. he coil would round on the inside of the control arm a bit more which would keep the truck a tad higher but turning it counterclockwise would end the coil on the bottom facing the passenger side which I think would drop it down a bit. i think it would work. I was just wondering if anyone has ran into this or if this is the way it should be. The coil will stay in and not pop out. Until I get to the otherside I wont know if both sides are consistent on how they fit. |
I have ECE 2" drop springs on my 67 and they line up perfectly. Call their tech line. ECE is a top notch outfit and they stand behind their stuff.
Here is a few pics,
THe stock spring compared to the ECE spring. When I align the tops you can see the only issue will be on the bottom control arm when installed. I do not see where this would be to big of a problem if at all as you still have a good contact area on the control arm. It just does not go as far as the stock spring. I think this will allow the truck to sit a hair lower in the front as the coil ending is on the inside of the control arm which is where most pressure is for holding the truck up. Both springs are identical compared to stock. ![]() ![]() ![]() |
x2 on calling tech support and send them the pics you showed us.
chevy truck fan
vagaschevy,
i had (have) the same problem on my '72. i installed 2" lowering springs & one spring does not "sit" right. the front view of the truck looks slightly higher on that side. ![]() ![]() ![]() good luck!! ![]() |
#11 | |
I just do not think that it would be a problem this way. but what do I know? LOL |
67-72 Addict!
They are probably fine. Now go out and slowly hit a few speed bumps in a shopping center to seat them. You will probably hear a "bang". Measure before and after doing this.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
#13 |
I agree with 70c10 above...
I would install with the top of the spring lined up as should be and drive a couple miles, allowing them to settle. Last edited by Kayotic; 01-30-2010 at 12:48 AM. |
#14 |
![]() Join Date: Jan 2009
I had the same problem with my springs as well. I bought mine from cpp. I went and bought a set from ece and they fit perfect.
Kevin 67 custom cab big window swb 350/700r4 4/6 drop tilt,a/c 69 custom/10 swb 350/350 4/6 drop tach,tilt 71 cheyenne super swb 454/700r4 4/6drop tach,tilt,a/c,bucket seats,speed warning 96 gmc swb ![]() |
#15 |
Tot Roddin'
vegaschevy...
Are you sure they are 2" drop springs? Not that it happens a lot but there's always the chance to receive different springs than what you actually ordered. I would give Stan/Mark a call and tell them the issues you are experiencing.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#16 |
I am not 100% sure they are 2" drop springs, I can only assume. They seem about 1.5" shorter then the stockers.
#17 |
Never Ending Projects
Remember, dropped springs are rated based on new stock height ones. Your almost 40 year old ones have sagged. That is why so many people get disappointed when they buy xx" drop springs and their truck ends up slightly lower or some cases even higher. Their original springs has sagged so much, they were like dropped springs. That's why ECE put pics up showing what trucks would look like with which drop.
Also different spring rates will play into things. A 500 lb/in spring the exact lenght as a 600 lb/in spring will sit lower because it only takes 500 lbs to drop an inch. I would have called ECE yesterday while they were open. Don't know if anyone answers the phone on the weekends. Good luck.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#18 |
Tot Roddin'
Mike they are in on Saturdays... had to make that call on more than one occassion.
![]() vegaschevy... did you measure the height of the truck prior to installing the drop?
#19 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Align the top of the spring.
Don't worry about the bottom. In post #1,... you need to rotate the spring clockwise. All springs are the same,... no left and rights. I would drive it. If you don't like the height,... start trimming them until they set like you want them to. The only other option is another set of drop springs. |
#20 |
I bought both small block and big block springs from ece and both sets had this problem, if it is one. I figure I'll wait till I have some weight on them and then see what the deal is.
http://67-72chevytrucks.com/vboard/s...d.php?t=288820 68 Chevy CST project 02 Chevy Silverado Ex.cab 71 Ford Torino Cobra |
#21 | |
I lined up the upper portion of the spring correctly in the pocket and the bottom end of the spring is about 1.5" short of sitting in the lower control arm pocket correctly. I planned on just running them as is. Let me know what you did. Thanks. |
#22 |
Return them and just cut your coils.....
my $0.02
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
#23 | |
#24 |
BOHICA
So did they finally settle in to the pocket?
#25 |
