Old 01-28-2010, 11:34 PM   #1
Kenbo-Slice
Kenbo-Slice's Avatar
Dropping a 2wd 1-ton dually. Questions.....
What is the easiest way to drop a 2wd 1-ton dually but retain the HD spring rate?
Is there a company that sells 1-ton drop coils for the front? For the rear, would spring under be the way to go? I want to bag it eventually, but for right now I just want it a few inches lower.
It's a Jeep towing machine! (at least it will be)
Kenbo-Slice is offline   Reply With Quote
Old 01-29-2010, 12:17 PM   #2
bodydropped68
bodydropped68's Avatar
Re: Dropping a 2wd 1-ton dually. Questions.....
drop spindles in the front and a shackle hanger kit for the rear will give you a few inches 2 1/2-3 in the front and 3-4 in the rear and you will still have you one ton towing capacities.
bodydropped68 is offline   Reply With Quote
Old 01-29-2010, 04:05 PM   #3
jitteryguy
GoatLube Experss
jitteryguy's Avatar
I use 2.5 inch drop spindle's and shackle/hager kit , tire's are right at wheel open'n .
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 01-30-2010, 08:25 PM   #4
Kenbo-Slice
Jitterguy, where did you buy the spindles and shackles? I have been looking for a kit but can't find one. One other thing, are the spindles for a 3500 the same for a 1500? I wouldn't think so. The spindles would be much stronger, no?
Old 01-30-2010, 11:56 PM   #5
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
I got my stuff here: http://www.sporttruckdirect.com/C30_kits.html
Parts arrived within a week. They have several drop levels.
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 01-31-2010, 12:27 AM   #6
Kenbo-Slice
Great Josh, thank you!
Old 02-05-2010, 12:28 AM   #7
jitteryguy
GoatLube Experss
jitteryguy's Avatar
AirBagit.com , I dont remember how much it was . I think about $350 to $400
'85 1/2 ton CCSB
'92 S10 350/350
Old 02-05-2010, 12:34 AM   #8
Kenbo-Slice
Thanks man, I'll check that out too. I appreciate it.
Old 02-05-2010, 12:38 AM   #9
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
I ran 3" rear drop on my 2500HD for a while and it towed great, anything more and I would suggest running air bags.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 02-05-2010, 12:41 AM   #10
Kenbo-Slice
Yeah, I don't wan't it slammed Just a bit lower. On airbaggit.com I could only find spindles for a C-10. I imagine the spindles for a C-35 are a little heavier?
Old 02-05-2010, 02:41 AM   #11
RunninLo
RunninLo's Avatar
you mean like this?:
and yes the R30/3500 spindles are beefier in just about every way.
Josh
88 4x4 crew DD
Old 02-05-2010, 03:08 AM   #12
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice looking dually!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 02-05-2010, 09:21 AM   #13
Kenbo-Slice
Josh
NICE! Yeah, like that. Any problems bottoming out RunninLo? Like I said before my dually is gonna be towing 1-2 jeeps 2 times a month or so.
Old 02-05-2010, 05:13 PM   #14
RunninLo
RunninLo's Avatar
Well Kenbo it is sitting on the x-member in front due to being aired out but when raised up it does fine. If I was going off road I'd take my v30 crew. As far as towing this will be set up to tow and I towed a lot with my '92 shop truck seen here:
And towing one of the show cars seen here:
If you're dragging the Jeeps to the parking paved parking lot at the entrance to the dunes either of these is fine but both max out at about 6" ground clearence.
Josh
88 4x4 crew DD
Old 02-05-2010, 06:10 PM   #15
Kenbo-Slice
Good deal man. Sharp looking rides! I want to do air, but at the moment I'm just looking to drop it a couple of inches.
Old 02-06-2010, 12:49 AM   #16
OARNGESI
OARNGESI's Avatar
Originally Posted by runninlo View Post
well kenbo it is sitting on the x-member in front due to being aired out but when raised up it does fine. If i was going off road i'd take my v30 crew. As far as towing this will be set up to tow and i towed a lot with my '92 shop truck seen here:
and towing one of the show cars seen here:
if you're dragging the jeeps to the parking paved parking lot at the entrance to the dunes either of these is fine but both max out at about 6" ground clearence.
Josh
off topic but any more pics of the hardbody
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 02-06-2010, 08:54 AM   #17
andrewmp6
More pictures of all of them.
andrewmp6 is offline   Reply With Quote
