![]() Join Date: Feb 2008
WTB: Brake Booster Rod/Brake Pedal Pin
I am looking to buy the pin and associated parts that connect the brake booster arm and the brake pedal arm on a 1972 power brake setup. The pin I am looking for exists on the attached blue truck but is missing on the attached red truck pic. Shipping to Denver, CO 80209. Thanks.
Joel Last edited by JJanzen; 01-29-2010 at 02:02 PM. Reason: To Add Pictures |
New Member
Re: WTB: Brake Booster Rod/Brake Pedal Pin
If I have one on this, you can have it. I'll be out there Sunday and I'll check for you.
![]() Join Date: Sep 2009
Joel, if drunkguy doesn't have one, we do and I will send it to no charge.
Hope that helps Paul
You can shear a sheep every year, but you can only skin it once The person dealing with facts is never at the mercy of the person dealing with theory 1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn 1975 Silverado 454 Crew cab camper special dually |
Redefining LowBudget
dumb question but since it looks like you just put a new booster on does it come with the rods out both sides.....I have the peddle assembly to put in my truck but the booster looks like JUNK and the rods wont come out either side??? just woundering if I need to find another set up??
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
If I understand the question correctly, with the booster there is one rod and one boot. The other rod/bracket is part of the brake assembly. The pin that I am looking for connects the two. Hopefully that helps.
J you need the pin, a tension washer and retaining clip. When all the dust clears let me know and I will send everything no charge.
Paul
New Member
I've got the pin, washer and clip in my pocket right now. Pm me where to ship it and I'll send it out today.
ok let me see if I can clarify my question
the rod that the pin your getting does it stay with the booster or does it just slide in then the boot goes over it?? and does the pin that pushes the master stay with the booster?? it seem like both are stuck in my booster and I dont want to be trying to get them out if they are supose to stay in it??
#13 |
both sides??? I was worried about the end with the loop on it I have been wiggling it for about a week and couldn't get it out...lmao!!
thanx
#14 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I could really use 2 pins with retainers if anyone still has any??
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
