Old 01-29-2010, 11:14 PM   #1
rex01atv
2000 silverado 1500 sagging on one side???
My truck is 3/4'' lower on one side to the other??? Last week it was level, but I jacked it up on the high side for maintance and after, it has been high ever since?? I looked to see if there is anything binding and everthing looks okay. Could it be a bad shock that is keeping the truck higher?? My truck is lowered 5/7 with control arms and flip kit that was done years ago.
rex01atv is offline   Reply With Quote
Old 01-30-2010, 11:29 AM   #2
JWall
Frequent Flyer
JWall's Avatar
Re: 2000 silverado 1500 sagging on one side???
Are you positive it wasnt that way before? Not doubting you but ALOT of chevy truck lean to the drivers side around 1".
Is that the way it is leaning?
Infact BellTech even sells a coil spacer to correct this.
- Justin
1 Owner 1976 SWB
Old 01-30-2010, 07:28 PM   #3
mycool72
mycool72's Avatar
my 4/6 DJM on my 05 sags a bit on the drivers side especially with a full tank of gas...barely enough for me to notice though....doesn't bother me a bit.
mycool72 is offline   Reply With Quote
Old 01-30-2010, 07:36 PM   #4
MXmaniac
MXmaniac's Avatar
Put a little air in the tires on the low side, and let a little out of the high side.
Andrew
'69 C-20(292, 4-speed) Retired Daily Driver
'64 C-10(250, 3-speed) Fixerupper
'97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver
If I only wanted two pedals I'd have bought a bicycle.
MXmaniac is offline   Reply With Quote
Old 02-01-2010, 10:07 PM   #5
rex01atv
Thanks guys, I think I figured the problem out. My air bag overloads were over extended and needed to sit back over the sleeve, that gave me a 1/2, but still 1/4 off, proabaly because of the tank being full???
