what are my chances of fire?
This is mainly aimed at guys that run dual exhaust with the gas tank in the cab. I am going to be runnign dual exhaust and the way it will be routed, it looks like the exhaust will pass right under the fuel lines on the passenger side. How close are you guys to the lines and, did you have to install a heat sheild of some sort?? Does anyone have pics of their exhaust running past this?
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
newly minted old timer
i talked about the same thing a while ago. i ended up buying a heat shield (made for over the rear axle on wood bed trucks) put it over the fule lines the best i could.. looks better, i feel better but its still not a good set up.
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
i was thinking of making a shield for it out of sheet metal. But I just wanted to see what others amy have done
Member since 2000
on the poly tankd they have a warning about putting item closer then 3 inches. talk to the exhaust guy he said not to trip cause heat wouln't really travel outward due to the car moving and wind. I got turn downs, lol the exhaust never went any further then the front of the axle. Heat shield should be some extra insurance and a little rest on the mind. i use to add heat shield that had a airbag between the coils, cause the exhaust pipe woudl run next to the it. never heard any complaints.
what do you all think about headder heat wrap? it comes in 1" by 50' rolls 24.95 at summit.?+-
'72 1/2 ton short box 468 BB forged crank/rods/pistons full roller. Msd 6 AL ignition turbo 400 tci. 2800 verter ladderbar/coil rear with currie built ford 9'' rear, 4.11 gears custom built rear frame tubbed, 33/19.50/15 rear m/t. m/t skinnies in front still under construction |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
Half a bubble off!
The heat shield couldn't hurt anything, and would give you peace of mind, so I would go for it dube!
Just call me LB. ![]() '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
![]() Join Date: Sep 2001
Wow....I've been worried about wiring causing a fire this whole time. Gee, thanks for the new worry Dubie! LOL
Let me know what you decide to do. I've got to spend some quality time one of these days replacing the fuel line from the tank to the carb. There's two spots where basic rubber hose is used to deliver fuel, and I don't like that one bit with all the heat flying around. My pipes are in bad shape from the collectors off the manifolds to the mufflers near the center support bearing, so heat is a concern for me too.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
It was just a brain fart i had while i was lying under the truck the other day. I will more than likely bend one out of sheet metal and just rivot it to the floor boards or something. Oh and thanks for the tip john about the fire extinguisher.
I'd say get some of that heat resistant tape, like you see on the plastic on some quads. Or like that header wrap. That seems like it'd be better, I'd say use that and try to run the lines away from heat. Therefore you wouldn't have to worry about riveting anything to the floorboards and you would have peace of mind. Just my 0.02.
Brandon |
registered IWATA user
since i cut my turndowns off my exaust bows str8 into my fuel cell, it about 2 feet from it though, and is inside a metal holder, buti still feel like one day i am gonn blow up
-'63 Ford Fairlane 500 coupe, v8, auto, faded and rusty. awaiting built roller 302 and some flat black -'99 Honda Prelude. vtech/5spd. no pipe, no intake, bone stock. awaiting new top end. -01 GMC Yukon SLT 5.3 dented and scratched with a noisy tranny. Take off that Von Dutch hat before i stab you with a 000 Mack. |
KEEP ON TRUCKING
id go 4 it
72 cheyenne 2wd lwb 71 k20 sons bassett va |
#13 |
I can imagine it now>>> Honey, my gawd, are you okay? What happened? Well I was driving home and wouldn't you know it, but my exhaust was gettin' pretty hott. Go Figure, exhaust gettin' hott. Then all of the sudden, out of nowhere, the d@mn truck just lit up. Not like a match, but like the God aweful hydrogen blimp accident. But I'm alright tho.
I'd say do something about it, and having an extinguisher, though is a good thought, it won't help much after the truck has been blown into a million pieces. Brandon |
#14 |
Old Skool Club
![]() Join Date: Jun 2001
I have dual Flowmaster 40's, UNDERNEATH my cab, between the frame and the rockers. My gas tank is still in the cab. I don't have heat sheilds between the mufflers and the cab floor (but probably should to keep the heat out of the cab). IF you run duals under a wood-floor bed, heat shields are nice to have, "just in case".
(The rest of my comments are not meant to be discourteous or disrespectful, but do represent MY opinion and MY feelings.) Right now, my youngest son is in Abu Dhabi, my youngest daughter (and family) are having to declare bankruptcy because a mobile home salesman screwed them (and told them to get over it!) and now, you bring up this issue about what? Gas tanks in the cab and the proximity of mufflers and tailpipes? So, I guess I have something else to worry about. Tell you what...call me in the morning about 5am, and see if you don't have to wake me up. I think I'm gonna put this one on the back burner. Honestly, I think you are making a mountain out of a molehill. No reputable muffler man is going to weld on anything that could blow up, which would happen long before the heat from a muffler or tailpipe caused an explosion! I think you'll be okay to let them do their job. If you are afraid of the possibilities, don't do it. Stay with a stock single exhaust system.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#15 |
i love summertime
Someone ask mandrinsixseven about electrical fires..lol he still has my fire extinguisher to this day...hahahh
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
#16 |
Personally, I carry a fire extinguisher! If you check around at your local boating supply stores there is a grey colored high temp fuel line that is available.... and it's been a while, but I think I paid about $3.50 per foot bulk. It's thicker, it's prettier, and it doesn't burn up. I currently have it running across the top of my intake manifold, and it's been there for about 3 years. You won't find it at your low priced stores, only those that deal with inboard V-8's and larger boats. The only thing better is the stainless steel braided hose, but that stuff is a lot of work. Hope this helps. TJ
1971 Shortbed 350/350 w/ Posi-traction 3:73's 1996 Chevy Silverado TJ in Springfield, Virginia Likes old Chevy trucks Drinks Miller MGD ![]() |
#17 |
extinguisher is a good idea. my truck came with one mounted on the passenger side kick pannle, perfect spot for it. i have a few rags behind it. stops any rattle and are handy!
here is a pict.. ill take a pict of my heat shield tomorrow/.
#18 |
Seasonal Poster
Hmm my horn button lit on fire a while ago, but i never thought about exhaust too close to the fuel lines, better check that out.
67 GMC Short Step 350/4-Speed/3.08 Posi Front/Rear Sway Bars Kelowna BC, Canada Member of DTPW |
#19 |
![]() Join Date: Feb 2001
I had a rol of header wrap I never used on my headers so I used it on the exhaust pipes that run from the headers to the supertraps behind the cab. an't believe how much cooler the floor is in the summer. Thats maily why I did it was to see if the floor would be cooler. It works great but if your gonna do it I'd get stainless pipes.
#20 |
Hey ChevLoRay, I didn't mean to spark something in you other than a personal opinion on whether it could cause a fire harzard. The reason I asked this question is that I am bending and installing the entire exhaust system myself and just wanted other members opinions on what they have done. It was just something I noticed on my truck while I was laying out the routing for my exhaust and it triggered a question in the ol brain.
I am in on way making a mountain out of a mole hill here bud. Just looking for some opinions before I tackle this project, so LAY OFF!!!!
