Old 01-30-2010, 02:46 PM   #1
chrislehr
Engine n00b
chrislehr's Avatar
Removing brake drum rivets..
before I pull out the grinder, I want to confirm these are the three brake drum rivets I need to grind off..
If anyone can answer quickly - I have the thing up on jackstands and really want to get this done today.
I am kind of shocked to see intact rivets.. the truck is 40 years old. Also, I have already adjusted the brakes all the way up and down, so I know the shoes are not holding it on
chrislehr is offline   Reply With Quote
Old 01-30-2010, 02:49 PM   #2
john
member #16
john's Avatar
Re: Removing brake drum rivets..
Yes that would be them.
john is offline   Reply With Quote
Old 01-30-2010, 02:50 PM   #3
fast_dev
fast_dev's Avatar
their the ones, you may have to grind them off and knock the hub out of the drum and then grind some more to knock them out the hub
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112
67 nova numbers matching 327 4 speed 13.6 @ 102mph
70 longhorn c-30 402/4 speed
70 c-10 swb 402, muncie 4 speed
94 s-10 350/th350 3:73 posi
71 c-20 402/th400 towrig for racetruck.
72 4wd lifted on 35's
72 350/3 speed winter beater
fast_dev is offline   Reply With Quote
Old 01-30-2010, 02:50 PM   #4
dhaymaker
dhaymaker's Avatar
Eliminating those rivets will allow you to separate the drum from the hub. They are a little harder to handle/reinstall, when separated, but you have to start somewhere!
don
"The DRBMan"
2014 Audi A4 (The Wife's Daily Driver)
2017 HD Ultra (The Cruiser)
2003 HD Fatboy (The Ride)
2001 Chevy Suburban (Another back up!!)
For the first time in forever, not a single 67-72 Chevy truck, Blazer, or Suburban on the property! Basically retired and getting the new Motorhome ready for some traveling. Doing a bit of work on the house getting it ready to sell! LOL!!
dhaymaker is offline   Reply With Quote
Old 01-30-2010, 02:51 PM   #5
chrislehr
Engine n00b
chrislehr's Avatar
Wait... reinstall?
I thought they were throw aways and not needed really.. educate me if not, cause I dont have a riveter!
Old 01-30-2010, 03:08 PM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
You don't have to rivet them back on. I drill them out with a 1/4" bit almost all the way through and chisel the head off and punch out the rivet.
dwcsr is offline   Reply With Quote
Old 01-30-2010, 03:26 PM   #7
chrislehr
Engine n00b
chrislehr's Avatar
I didn't think you had to - thanks for confirming. I just don't get why my 40 year old truck would have them riveted on.
Its making me wonder if my odo is 49k or 149k.
Old 01-30-2010, 06:13 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the stock trums were made properly when men were men and steel was steel. They have been known to last well over 100k.
If your originals are still good, then put them back on. The replacement ones are junk IMO.
Old 01-30-2010, 06:29 PM   #9
chrislehr
Engine n00b
chrislehr's Avatar
I guess I should have made post #1 clearer - I was trying to check the pads. Luckily, didnt get the rivets all out before I was told to remove the axle bolt/dust cover. Doh.
Old 01-31-2010, 01:44 AM   #10
chrislehr
Engine n00b
chrislehr's Avatar
while I have a thread going - whats the purpose of the spring coil wrapped around the drums?
Old 01-31-2010, 02:10 AM   #11
shaneo2112RUSH
Junior Member
shaneo2112RUSH's Avatar
my guess is the springs were used to keep tention on the drum from warping when getting hot or overheated. But not shure!! some one can chime in and educate me
also when hammering the rivets out, Be careful!! i kind of got crazy with the hammer and bent the wheel hub in three places where the rivet sat and i was really shock i actualy bent the hub!! I would prefer to drill the rivet out completely
1968 LWB C10 "Project LADY EYE SORE" (She is my baby and sent me to the hospital 3 times for eye injuries lol) who said love hurts??
shaneo2112RUSH is offline   Reply With Quote
Old 01-31-2010, 02:18 AM   #12
LowBow
Self Made Hundredaire
LowBow's Avatar
The spring was used to quiet the harmonics. That's the only use I know for them.
'79 corvette - all original 49k car!
'03 Z71 ECSB - gas hog
'57 Belair 2 door hardtop. Love of my life!
LowBow is offline   Reply With Quote
Old 01-31-2010, 02:30 AM   #13
Longhorn Man
I agree with the harmonics... a slight ringing can be heard if the spring is missing, some will tell you it is for cooling though.
Old 01-31-2010, 03:28 AM   #14
Rooster's 67
Rooster's 67's Avatar
yup the spring around the circumference is there to dampen harmonics that could cause unwanted noises during brake application.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 01-31-2010, 03:43 AM   #15
mr48chev
mr48chev's Avatar
Some guys have to knock the rivets off so alloy wheels will seat flat on the drum but the only other reason to cut them off would be to replace the drums. By the way, drum brakes don't have "pads" they have "shoes".
Old 01-31-2010, 05:13 AM   #16
mclairmo
My 68 still had the darn rivets in place and I'm sure my truck has a billion miles on it. Shocking that they last so long.
mclairmo is offline   Reply With Quote
Old 01-31-2010, 04:00 PM   #17
shaneo2112RUSH
Junior Member
As you can see the bend in the hub from hammering on the rivet after the head was grounded off, it was bent all the way around where the rivet sat!
I didn't realize it was bent after 5,000 to 10,000 miles driving on the new shoes and drums. I didn't get any vibrations at all luckly!!
both drums still in good shape and no lip but different type! one has rivet holes and the other without, both were bought at the same time here at Chicano Zone!! going to get rid of these and switching to front and rear disk later in my build
Old 01-31-2010, 07:39 PM   #18
Longhorn Man
they also don't have the holes for adjusting the shoes up, or the lip for the spring.
Old 01-31-2010, 10:13 PM   #19
dwcsr
Hollister Road Co.
dwcsr's Avatar
This is the reason for drilling the rivets almost all the way through. When you drive them out the colapse inward and come out very easy.
