01-30-2010, 02:58 PM | #1 |
Compressor question
Can Viar compressors be mounted in any position? TIA.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-30-2010, 03:06 PM | #2 |
Re: Compressor question
I was told yes.
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 Last edited by jmedero; 01-30-2010 at 11:41 PM. Reason: reasons |
01-30-2010, 04:22 PM | #3 |
01-30-2010, 04:46 PM | #4 |
I really have no idea. I was told it is for the air filtering to keep trash down to a minimum. I really don't buy it it was just what I was told.
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
01-30-2010, 04:58 PM | #5 |
mine is mounted sideways on the frame with no problems. been that way for a year.
01-30-2010, 05:26 PM | #6 |
How does the compressor know the front of the truck from the rear?
01-30-2010, 11:28 PM | #7 |
Nothing to see here.....
come on Shane, built in directional finder..... duh!
I read somewhere, probably here, that Viair recommends not to mount them upside down. however, many have done so without problem one.....
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
01-30-2010, 11:43 PM | #8 |
nevermind. I was just saying what was told to me. I never said the comp had knowledge or could tell... nevermind
sorry Rob.
01-31-2010, 04:52 AM | #9 |
i've been told by others not to mount viairs upside down
01-31-2010, 09:39 AM | #10 | |
Redefining LowBudget
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
01-31-2010, 09:44 AM | #11 |
From the horses mouth(Viair website)
Q: Is it possible to mount the compressor sideways? Must it be mounted with the cylinder upright? A: Yes, you can mount our compressors in any direction or position because they are oil-less. The only position we do not recommend is upside down, since heat tends to travel upward, and does not dissipate well in the motor housing of the compressor. Q: If I mount my compressor sideways, is there anything I should be careful of when doing this? A: If you mount your compressor sideways to the frame rail, you should periodically check to make sure that your compressor is mounted securely. Use a thread-locking compound to keep the bolts from backing out and causing the compressor to fall off of the vehicle. |
01-31-2010, 09:22 PM | #12 |
i had mine upside down for 3-4 years as a daily driver with no problems
03-19-2011, 03:18 PM | #13 |
Life, Be In It.....
I was just going to start a thread asking this question. Glad I used the search function.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
03-21-2011, 10:06 PM | #14 |
low n' slo
may sound dumb but do you have a drain port? mine was doing that for a while and i couldnt figure it out, til i drained the tank lol
mine doesnt have a drain port, so one day i pushed a screwdriver in the schrader valve i have on my tank and it spit water out. after that, it built right up. i know, i need to get a drain port AND a water trap lol
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
03-21-2011, 10:55 PM | #15 |
i have had two 480's mounted upside down for 2 years now with zero problems, and i cycle the hell out of them. i dont think you will have a problem if you do mount them in this way. daniel.
03-22-2011, 02:08 AM | #16 |
Right side up for me bro
03-22-2011, 11:44 AM | #17 |
i had (4) 450s mounted upside down on my dailey for 5 years no issues the dude that bought it is still rockin the orig compressors 10years later LOL
