01-30-2010, 04:36 PM | #1 |
build sheets
Hi everyone,new here,just bought a 1986 GMC 3/4 ton. I have been searching for a build sheet with no luck,can anyone help me out..Cheers Terry
01-30-2010, 05:20 PM | #2 |
Re: build sheets
I've had my truck completely apart and never found one. Location (or inclusion) of build sheets may vary a little from plant to plant; Do you know where your truck was built?
Best place to look would be in the seat cushions, inside the doors, under the floor mat/carpet, inside the dash, maybe even inside the A pillar. Is there a SPID label in the glovebox? If so, that will tell you all the option content there is to know....or are you looking for sentimental reasons? K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-30-2010 at 05:26 PM. |
01-30-2010, 05:26 PM | #3 |
Re: build sheets
Yes I have found the build sheet in the glove box ,don't know how to decode it
01-30-2010, 06:08 PM | #4 |
Re: build sheets
Ok, good. We certainly know how to do that!
If you would like to post a pic or list them here I'll take a shot at it. Or you can try here: http://www.73-87.com/chevy_ids/rpomenu2.htm Or here: http://www.cadillacfaq.com/rpo/index.php K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-30-2010 at 06:10 PM. |
01-30-2010, 06:09 PM | #5 |
Re: build sheets
My build sheet is clearly located in the glovebox. Codes, options etc. Not sure if you would call it an actual "build sheet" or not as it doesn't have any of the dates, shipping order or anything like that, from what I remember anyway. For what it's worth, Mopars are under the seat tucked in the springs. never saw an actual sheet stuffed anywhere on a Chevy truck before.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip '68 Plymouth Road Runner 383, 727, 3.23 Sure Grip '89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip '77 Dodge Monaco ex cop car 440, 727, 2.71 '79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip '12 Dodge Challenger SRT8 392, M6, 3.92 '85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73 |
01-30-2010, 07:08 PM | #6 | |
Re: build sheets
Correct: "SPID" label, or service label is located in the glove box. "Build sheet" is an actual build document, used to aid the workers as the vehicle went down the line. There was no requirement to place the build sheet in the vehicle, but usually it got left there because it was easier than throwing it in the trash. That's why they can be found in such different places, varying from plant to plant, day to day, shift to shift and worker to worker - or why some vehicles can have two or three (including wrong ones), some vehicles have none. Here is one from a Pontiac GTO, found above the gas tank: We also had something called a "build manifest", which was like a bunch of the build sheets printed together on that old "tractor paper" (with the little holes on the side). This was something they gave to certain workers, so they knew what option content was coming ahead of time, usually passed out for one day (two shifts) worth of vehicles. Those got thrown in the trash as well when we were done with them. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-30-2010 at 07:15 PM. |
01-30-2010, 09:13 PM | #7 |
Old Heap Driver
Re: build sheets
Keith,
I want to thank you for joining this site. You are a wealth of information for the members, I know I enjoy each and every bit you share with us. Thanks!!!!!
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
01-30-2010, 09:46 PM | #8 |
Re: build sheets
Thank you -
I'm never quite sure what's going to be a "hit" and what's going to be a "miss" - so I just keep puttin' it out there! Thanks again, K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
01-30-2010, 10:41 PM | #9 |
Re: build sheets
ok found this A52......................D44
E63......................GU6 LE9......................MXO N41......................V43 XYK......................ZYK YYL......................Z49 Z31...................... 624.....................400 1AA Thanks for ur help |
01-30-2010, 10:58 PM | #10 |
Re: build sheets
I think mine came from under the rubber floor covering, it's a 78 built in Atlanta.
01-30-2010, 11:05 PM | #11 |
Re: build sheets
I usually find them under the seat springs,especially on Janesville builds;look up at the bottom of the seat from underneath on the passenger side;you will have to pull the seat to remove them in 1 piece.
01-31-2010, 11:21 AM | #12 |
Still plays with trucks
Re: build sheets
Not truck related but I found a build sheet on a friends Nova when we had it up on the lift doing some work on it. I had the work lamp at the right spot that when I was looking forward I saw up inside the subframe rail and saw some paper in there. It was the build sheet and it was complete and undamaged after 16 years in there exposed to the elements.
We found another one in the back seat and another on top of the gas tank on that same Nova. I searched every inch of my Camaro and didn't have a single one.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
01-31-2010, 11:51 AM | #13 |
Re: build sheets
I recently put new carpet in my 87' V10 and when I pulled up the factory carpet, there were 3 pairs of white cotton work gloves underneath. A couple of the gloves were partially underneath the black sticky dampening mat also, so I knew they were from the factory. I figured an assembly line employee just tossed them in before the carpet was put down. I pulled out one pair to show my wife (couldn't have cared less!) and left the other 2 for nostalgia.
01-31-2010, 11:56 AM | #14 |
Re: build sheets
There is a service that will document your truck. It is in Canada if your interested the cost about 50.00 send me an email and I'll send you the info.
My Truck's not leaking its marking its territory! |
01-31-2010, 02:23 PM | #15 |
Re: build sheets
deleted post
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-31-2010 at 02:36 PM. |
01-31-2010, 02:25 PM | #16 | |
Re: build sheets
K
01-31-2010, 02:32 PM | #17 | |
Re: build sheets
A52 - bench seat D44 - painted buckeye outside mirror E63 - fleetside box (E62 is stepside) GU6 - 3.42 rear axle LE9 - 305 cu in engine MX0 - automatic trans N41 - power steering V43 - painted step bumper XYK, YYK, ZYK - tire options, X for front, Y for rear, Z for spare. YK = LT215/85R16 BL Highway Z49 - Canadian equipment Z31 - Advanced price sheet 1AA - Incentive Retail amenities - delete
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-31-2010 at 02:42 PM. |
01-31-2010, 02:45 PM | #18 | |
Re: build sheets
K
01-31-2010, 04:53 PM | #19 |
Re: build sheets
Here's what mine looks like.
01-31-2010, 07:38 PM | #20 |
Re: build sheets
Thanks everyone ,and last thing Im lookin for is what rearend is in it (without crawling around in the snow).and again thanks..Terry
01-31-2010, 08:57 PM | #21 | |
Re: build sheets
Are you asking what size rearend (ie, 8.5" ring gear, 9.5" ring gear, etc)? That will depend on the series (10, 20, 30) which we haven't determined yet. What's the model number shown on the SPID label? K
01-31-2010, 09:01 PM | #22 |
Re: build sheets
Chevyrado - thanks for posting that. I am going to spend some time poring over that.
I wonder if/when the Lakewood plant stopped building trucks. I have never been there; by the time I started traveling the plants building C/K trucks were Flint, Pontiac, Oshawa, St Louis and Janesville. I think Arlington and Ft Wayne came later, with the GMT400 versions. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-31-2010 at 09:04 PM. |
01-31-2010, 09:44 PM | #23 |
Re: build sheets
02-01-2010, 02:54 AM | #24 | |
Re: build sheets
I don't know when It quit trucks. I know Grandad's, '62 c10 and his 78 c20 were built there as well as my dads 77 c10. My uncle worked there his whole career, but he died years ago so that info is lost. I think the plant now does something with sheet metal. IIRC the sign out front changed from assembly years ago to now say "Sheet metal Fabrication" or something like that. Last edited by 78 Chevyrado; 02-01-2010 at 03:00 AM. |
02-01-2010, 03:25 AM | #25 |
Re: build sheets
Mine was under the seat. It fell apart when I tried to take it out. It was built in Baltimore. Havent looked for one in the K5 yet, it was built in Flint.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ Last edited by bluex; 02-01-2010 at 03:28 AM. |
