Old 01-29-2003, 02:57 PM   #1
694X4
694X4's Avatar
starter problem
Ok this sounds simple but for some reason it's not. The whole story: Truck caught fire from a short. Put in used harness from firewall out. new starter, battery, voltage reg., alt., flex plate, and I have used every shim combination possible even putting shims on one bolt only thinking that maybe it would do some thing but it still skips teath. I went and ordered the bracket thing from a dealer...still skips. I can get it to sound perfect then after 10-15 starts it starts skiping again and the whole process starts over. Oh and it is a 69 gmc 2wd 350/350 hei if you need more info let me know.
69 3/4 ton 4x4 gmc with 6" sky jacker soft ride. 350 / th350 / 205
work in progress
694X4 is offline   Reply With Quote
Old 01-29-2003, 09:58 PM   #2
JQ-72
JQ-72's Avatar
Yeah, me too! I have a 72 350 original motor that I have put 7 different starters on. No matter how you shim it, it either skips or grinds something mad when turning over. I have shimmed one side at a time, both sides, no shims, this starter situation has made me use words that I should be ashamed of!!! Anybody??
Joshua
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track
72 Cheyenne Super swb. 350/350 A/C, bucket seats
72 Cheyenne swb. Factory 402/400, tilt, posi, A/C
72 Cheyenne Super K-10. 350/4 spd., posi.
72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack
72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior
JQ-72 is offline   Reply With Quote
Old 01-29-2003, 10:05 PM   #3
magoo72
magoo72's Avatar
when i had the problem i found out i had the wrong starter,i tried one from a different year and they were almost identical but in fact they were different,somthing about the way they bolted up. not sure what it was ,but i no longer have the problem.
magoo72 is offline   Reply With Quote
Old 01-29-2003, 10:22 PM   #4
pound41
I have a 71 blazer that I have owned for over 20yrs. I have had the same trouble for many years. I had put a flywheel in it many years back and still the same thing. Good for a while and then back to draggin. I got my starter from a discount auto chain that had a lifetime warranty. and I was constantly exchanging them. Anyway this trouble went on spractically for 13 years . I have a brace on it and everything. anyway 6 years a go I had the tranny rebuilt and it hadn't done it for several months prior. After I got it back it was grinding again. I took it back and told them. They put another flywheel in and told me to stop using those damn cheap starters with those cheap starter gears. I paid for a precision starter which is a company that rebuilds them here in Virginia. Anyway knock on wood that was 6 yrs ago and no trouble and the same starter
pound41 is offline   Reply With Quote
Old 01-30-2003, 10:12 AM   #5
694X4
694X4's Avatar
I have tried 5 starters in one monthes time.
work in progress
