Old 01-30-2010, 05:06 PM   #1
69oldog
69oldog's Avatar
Cool 3 on the tree problems
Hello,I have a 1969 c/10,292,3 on the tree,the problem is it won't shift from first to second while running,I tried adjusting linkages,clutch still no luck.Does anyone know if there is a rebuild kit for the steering column mechanism???I want to keep this truck as orignal as possible,so I don't want to put it on the floor.ANY suggestions?? Thanx,Todd
69oldog is offline   Reply With Quote
Old 01-30-2010, 05:46 PM   #2
Sammy
Re: 3 on the tree problems
Your best but most expensive choice would be to buy a new column from one of the manufactures. Get a column that is stainless so you can paint it the desired color. Next is to contact one of the folks who do the rebuilds. There are a few around, there are some on ebay. They may rebuild yours for you or use it as a trade in. Then lastly from the parts board find one used that the seller would know how well it operated prior to removal. Most everyone who do restoration would be changing from the manual anyway they might have a decent column.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 01-30-2010, 07:00 PM   #3
rsavage
rsavage's Avatar
When you adjust the linkages, disconnect the linkage bars from the tranny dog ears, make sure that your dog ears on the column are centered over the nub that picks them up so to speak. Make sure the transmission dog ears are in neutral and adjust rods to meet them. When you shift an old warn column, you will find that you can develop a feel so it won't lock up on you when you shift from 1st to 2nd. Go straight up to neutral towards reverse without pressing the shifter down, then straight down in neutral and straight up to 2nd. If you don't and try and shift it from 1st to second on a straight diagonal line without 90 degree corners, the column dog ear for 2nd and 3rd won't be picked up and you will be locked in 1st. You will also need to develop a knack for quickly exiting the cab (engine off), popping the hood, and yanking the jammed linkage back to neutral position, jumping back in, refiring and going again. Over the years I had a lot of worn 3 on the trees and they all did the same thing.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 01-30-2010, 09:09 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Search the FAQ's for a tutorial on how to adjust the 3ott.Also clean and lube the unit well caked up dried out grease in the mechanism can cause problems.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-30-2010, 09:38 PM   #5
69oldog
69oldog's Avatar
Thanks for all the responses so far,I will try some tomorrow.
Old 01-30-2010, 11:16 PM   #6
69 longhorn
3 on the floor, I know that was not what you asked......but you get to play with your bestest gals leg when you are shiftin Crazy AL,52 yrs old , but goin on 25! One old man told me yrs back...."growing old is manditory, but growing UP is optional
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 01-31-2010, 10:12 AM   #7
69oldog
69oldog's Avatar
Went FAQ tutorial on how to adjust and it shifts great!!!Lubed everything up real good!!!Thanks for everbodys suggestions.
Old 01-31-2010, 01:58 PM   #8
Conroe trucker
SWBs: 67 2x4, 67 4x4, 70 4x4
Check out some of the 55-57 parts houses for the bushings for the transmission linkage.
There were poly bushings in the shift arms on the column, and at the trans.
I put new ones in mine, and it felt like a new car, very tight.
Shift pattern as tight as a new vette.
But, if the synchros have gone out the rebuild is not that much.
FINISHED Project thread: 67 SWB 4x4
FINISHED Project thread: 67 SWB 6 cyl cruiser
Project thread: Road Toad 70 SWB Step, 4x4, 292, 3OT
01 C5 convertable
08 Z06
Conroe trucker is offline   Reply With Quote
Old 01-31-2010, 04:08 PM   #9
Shaky
Six in a row makes it go...
Shaky's Avatar
Three-on-the-tree: the best security system around! Sometimes even the owner can't drive it!
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
