01-30-2010, 07:30 PM | #1 |
Proper way to lubricate speedometer cable
I have a 87' V10 and my speedometer is bouncy from a stop up until about 35 mph. After that, it levels out but still moves a bit. I want to pull out the cable to clean and grease it, but was wondering if the best way is to pull it out from the cluster end, or the transmission end? I made the stupid mistake of removing my TV cable one time and had the Old Faithful of tranmission fluid come pouring out, so removing anything from a tranny when full scares me. So, best end to remove it from, will tranny fluid come out if removed from that end, and any other caveats with doing it. I'm also going to use PB Blaster Garage door Lube. Had good luck with that stuff. Thanks!
01-30-2010, 08:18 PM | #2 |
Another Day, Another Dollar
Re: Proper way to lubricate speedometer cable
hey i dont know about 2wd's, but on my np203 i can pull the spedo cable right out of the T case with no problems.
i'm not sure how well lubing it will work in the long run, i picked up a new cable about a year ago from lordco. it was only $20
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" |
01-30-2010, 08:20 PM | #3 |
In the Forgotten far North.
The cable will only come out from one end and if I remember right, it's the tranny end that the speedo cable core will slide out of.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
01-30-2010, 08:56 PM | #4 |
Active Member
If I recall correctly, the cable will only come out from the end behind the speedometer cluster. Don't worry- No fluids will come out when you take the transmission end loose.
When you lubricate, use a graphite based lubricant, it should last longer than WD 40 or similar lubes.
Lane 1979 Chevy SWB- (Second owner- Father in Law was first) 1979 Chevy Silverado SWB-Red/Red |
01-30-2010, 09:22 PM | #5 |
The One And Only !!!
Out the top and you shouldn't have to remove the bottom from the tranny to re-install if you give it a slow turn when getting close to all the way in.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
01-30-2010, 09:28 PM | #6 | |
01-30-2010, 09:40 PM | #7 |
Old Heap Driver
I had to do some digging to find this................
Years ago my brother had a really neat tool for lubing speedo cables, worked great.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
