Old 01-30-2010, 07:44 PM   #1
grs
Unhappy Sway bar
Will a sway bar stop the truck from dipping down when I make a turn? The body on my 69 truck is not on the frame straight. Someone did a body off. I dropped the front 2 and 1/2 inches, and added 22 inch wheels. The wheel rubs the front fender a very little bit when making a left turn. Please email me at. gsgman2@sbcglobal.net
grs is offline   Reply With Quote
Old 01-30-2010, 08:04 PM   #2
hicktownhotrodder
Rollin Coal
hicktownhotrodder's Avatar
Re: Sway bar
Welcome to the site from rockford! a sway bar will greatly reduce body roll if thats what you're asking.
I have three letters to all these import guys:
God-Made-Chevy
04 GMC Sierra 2500HD Duramax
1972 Chevrolet C-30 Dually Pickup stock? 350 SM465 four speed
1977 GMC K-35, TH-400, 4X4 450 horse 454(dad's)
1993 Dodge cummins 5-speed DEAD!!
hicktownhotrodder is offline   Reply With Quote
Old 01-30-2010, 08:11 PM   #3
71swb4x4
71swb4x4's Avatar
Re: Sway bar
Are you sure the body is on incorrectly? It sounds like you could have a coil spring that is not ceated correctly which could cause one end to sit lower or higher than the other. If someone heated the springs, or cut them unevenly, that could also cause that.
A sway bar is a must on these trucks. It is one of the sinlge best handling changes you can make, and it's cheap too.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-30-2010, 08:16 PM   #4
grs
Unhappy Re: Sway bar
The body is off set. It was hitting before and after I had stronger front coils installed. The new coils did improve it a little. Thanks
Old 01-30-2010, 08:25 PM   #5
hicktownhotrodder
Rollin Coal
Re: Sway bar
are the body mounts new? that could do it too.
God-Made-Chevy
Old 01-31-2010, 10:50 AM   #6
grs
Re: Sway bar
The body mounts are new. Thanks
Old 01-31-2010, 12:38 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Sway bar
It could be related to the size of the wheel/tire combo on the truck and the BS (backspacing) of the wheels. Can you provide the specs of the wheels/tires?
A swaybar will greatly help body roll on your truck, but if you're making minor turns and the wheels are bottoming out, there's another problem.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-31-2010, 12:51 PM   #8
OhOneWS6
OhOneWS6's Avatar
Re: Sway bar
How about some pics?
OhOneWS6 is offline   Reply With Quote
Old 01-31-2010, 03:12 PM   #9
grs
Re: Sway bar
The right wheel is out further then the left one. I will get a sway bar, It doesn't rub turning to the right. The truck has 22 inch Coys wheels. My son bought them for me. I am going to give him the truck when I am tired of it.
Old 01-31-2010, 04:27 PM   #10
OhOneWS6
OhOneWS6's Avatar
Re: Sway bar
Great looking truck. How about some close ups of where it is rubbing.
Old 01-31-2010, 04:55 PM   #11
grs
Re: Sway bar
You can't see where it is rubbing. You may be able to see how the right tire is farther out then the left one. You have to be going fast while making a left turn to get the right tire to rub, or hit a big bump going fast. Thanks for trying to help.
Old 01-31-2010, 05:29 PM   #12
OhOneWS6
OhOneWS6's Avatar
Re: Sway bar
Pics are worth a thousand words. I can see what you are talking about. I kinda doubt a sway bar is going to help that. A sway bar is still a good inexpensive upgrade for the truck though.
The fit and finish on these old trucks is no where near what it is on most new vehicles. I'm betting there is not really anything wrong with the truck. It's just a result of the truck being lowered with 22's. Maybe someone with a better suggestion on fixing it will chime in now that you can see it.
Old 01-31-2010, 06:11 PM   #13
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Sway bar
First thing, beautiful truck!
Maybe it's just me, but look at how much farther the front wheels are pushed out compared to the rear wheels. I do see how the right wheel is pushed out farther than the left wheel, but I'm wondering how the wheels were ordered and what BS was used.
Could you get us a pic of the front suspension? Did you rework any of the front steering parts?
-Nate
Old 01-31-2010, 07:44 PM   #14
roughedup72
roughedup72's Avatar
Re: Sway bar
I noticed that the fronts are further out than the rears also. Looks like back spacing. Maybe the fronts should be on the back and see if that helps. Good luck, Nice truck and your son is lucky.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod.
roughedup72 is offline   Reply With Quote
Old 01-31-2010, 07:59 PM   #15
Hart_Rod
Hart_Rod's Avatar
Re: Sway bar
Looks like backspacing is the problem. The rear will be tucked in a little more due to it being a 69 with the narrower rearend.
Hart_Rod is offline   Reply With Quote
Old 01-31-2010, 08:02 PM   #16
JRBECK64
Re: Sway bar
Great Looking Truck,
I put a Swaybar on the Front of my Sons 64 Shortwide and it made a huge amount of difference in how it handles now. The Truck doesn't dive into turns anymore and Im even considering putting one on the rear of the truck. Is there a difference in the back spacing on the wheels from front to back? Is the Differential original or has it been replaced?
JRBECK64
JRBECK64 is offline   Reply With Quote
Old 02-01-2010, 05:29 PM   #17
grs
Re: Sway bar
The back spacing is the same on all 4 wheels. The rear end is orginal. A 12 bolt.
Old 02-02-2010, 09:37 AM   #18
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Sway bar
Best guess for me... the BS is causing you some issues.
Do you know if the truck was ever wrecked? The body panels could be off a little as well causing it to rub on one side and not the other.
-Nate
Old 02-02-2010, 12:19 PM   #19
grs
Re: Sway bar
I don't think it was ever wrecked. It does have a 71 to 72 grill, bumper, and hood on it. I am going to put a sway bar on it, and then just live with it.
Old 02-02-2010, 12:50 PM   #20
HuggerCST
HuggerCST's Avatar
Re: Sway bar
Nice truck! If you get a sway bar, get a big one. I have 1 & 1/8" on mine, and I LOVE it. There is a big difference in handling between a 1" and a 1 & 1/8". Mine came off of a mid 80's 3/4 ton chevy. (bolt on swap)
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 02-02-2010, 01:11 PM   #21
grs
Re: Sway bar
Early Classic has a 1 and 1/4 inch sway bar for a dropped front end. It cost $159.00. I think I will buy that one.
