Old 01-30-2010, 08:19 PM   #1
byates2
byates2's Avatar
Oil Pan Gasket problems
So i have a 383 that im kind of restoring. By kind of i mean i'm replacing the gaskets and painting it so it looks pretty again. The engine is almost new so there's no problem there.
My dad told me that chevy has a bad rep with their oil pan gaskets and if you dont do it the exact right way you're gonna get a leak down the road much faster then you want.
I bought the best gasket i could find (its a blue rubber type one) I also bought gasket maker to apply to both sides of the gasket in order to insure an airtight fit but the gasket didnt stick onto the pan with the gasket sealer. so im wondering if anyone has any suggestions as to how to go about this the best way possible?
1967 C10 Long Bed, Soon to have a 350
1997 Chevy 2500 454 BB
byates2 is offline   Reply With Quote
Old 01-30-2010, 10:24 PM   #2
RW71
RW71's Avatar
Re: Oil Pan Gasket problems
Is it a one piece gasket?
RW71 is offline   Reply With Quote
Old 01-30-2010, 11:15 PM   #3
into69z
"brand new second-hand"
into69z's Avatar
I put one of those expensive blue one piece pan gaskets and it leaks like the exxon valdez!......can't wait to spend more money on the old cork gasket and try again...
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
Old 01-31-2010, 01:41 AM   #4
67ss&99ss
Andy
I have a blue one piece felpro on my truck and I don't have any leaks. I installed it with the engine out of the truck. I cleaned the block well, wiped the pan rails down with acetone, let it dry, put red silicone in both corners of the timing cover and the corners of the rear main seal area, dropped the pan gasket on, then the pan and I made a few passes when tightening the bolts. I found out you have to tighten these gaskets down a good bit. They have steel o-rings in them where the bolt goes through, so they are impossible to over-tighten. A few days after you first put it on, recheck the bolts to make sure they are tight, and thats it.
1967 Camaro SS 406|522hp/514ft lbs|M20 Muncie|3.73s|Posi
1969 CST/10 383|Aisin AR5 5 speed
1972 K5 350|Turbo 350 4x4
2005 Duramax 2500HD 4x4
67ss&99ss is offline   Reply With Quote
Old 01-31-2010, 05:55 AM   #5
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I have one of the one piece gaskets on mine too. It worked great but I forgot the 350 that I have is out of a 78 so it takes the thick front gasket and I bought the thin style. So it leaks around the timing cover, but that's not its fault its mine! I bought another but haven't had time to put it on. Don't use any sealant except for small dabs at the corners of the timing cover and rear main otherwise you won't be able to reuse it next time.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 01-31-2010, 07:47 AM   #6
jim zag
ENGINE BUILDER
jim zag's Avatar
I have discovered why so many Small Blocks leak in the front where the pan and timing cover meet. The new timing covers have the pan seal piece spot welded on with only a few spot welds. The oil coming out of the front main bearing goes in between the spot welds and leaks out in front of the pan gasket. Look at your timing cover. I took a flashlight and I could see light in between the pieces. The original GM covers had one long weld. I am now soldering this area before installing any covers. Make sure the front pan seal is a snug fit in the cover. Most aftermarket covers do not hold the front rubber seal tight. Use a pair of pliers to squeeze it together. Most of the aftermarket stuff from Taiwan or China does not fit well!
JIM ZAG
jim zag is offline   Reply With Quote
Old 01-31-2010, 08:27 AM   #7
cdowns
cdowns's Avatar
the felpro one piece gaskets r great
the main problems are the oilpan bolt holes if they've been overtightened they get dimpled and cause leaks check the mating surface with a straight edge
also cheapo chrome pans leak good
Old 01-31-2010, 02:15 PM   #8
67ss&99ss
Andy
Agreed! I bought a trans dapt timing cover for my 406 when I had it built and it was a piece of sh*t! Within 50 miles of me putting the engine in, it blew the seal out of the front of the timing cover and it had oil everywhere! I will never use a cheap store bought timing cover again. Whenever I go to swap meets I always pick up a few original gm covers so that I will have plenty on hand for future rebuilds.
Old 01-31-2010, 02:33 PM   #9
big_al_71
big_al_71's Avatar
I bought a brand new oil pan and used a felpro one piece gasket when I built my engine and so far so good zero leaks...it may be worth to just put a brand new oil pan if yours is old.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-31-2010, 07:27 PM   #10
67ss&99ss
Andy
If you get a new pan, be sure to get a GM pan, or quality aftermarket pan, like moroso. I bought new "cheap" pan from a super chevy swap meet and the builder couldn't use it because it didn't have any baffling inside it that prevented the oil from going to the front of the pan.
Old 01-31-2010, 07:37 PM   #11
junkyardjohn
junkyardjohn's Avatar
Those one piece fel-pro pan gaskets are fantastic. I've used them quite a few times & never had a failure. (knock on wood)
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
