Old 01-30-2010, 08:37 PM   #1
chevelle518
Stripping Paint
I have been a new member for a couple of week's and really enjoy my 64!
I have a tip for everyone!!!!
A friend told me about the way he stripped paint off his wheel's and boy does it work!!
I was wanting to completely remove paint from all panel's under the hood and just didn't use wire brush and sand paper.
I poured 4 gallon's of Muriatic Acid in a tub with 4 gallon's of water and put the part's in and in overnite for small piece's and 2-3 day's for bigger part's.
I put my fender in to remove old bondo and rust and it really worked. I was able to just lift the bondo out with my finger.
You guy's may want to try it.
PS It burn's like HELL if you have a cut on you hand, USE GLOVES!!!!!
chevelle518 is offline   Reply With Quote
Old 01-30-2010, 11:01 PM   #2
orange66fleet
Lowered in Cleveland
Re: Stripping Paint
That sounds great, where do you get the acid and what does it cost.
orange66fleet is offline   Reply With Quote
Old 01-30-2010, 11:06 PM   #3
60ratrod
yes, i do
60ratrod's Avatar
Re: Stripping Paint
i think you can get it at your local hardware store like lowes or home depot. not sure of the price though. and i hear it makes for an awesome degreaser
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 01-31-2010, 02:09 AM   #4
Captainfab
60-66 Nut
Re: Stripping Paint
Muriatic acid is commonly used to clean concrete and masonry, so places that deal with those items usually carry it. I sometimes use it full strength to romove zinc/cad plating on things I want to weld on. I haven't tried it on paint or grease. I'll have to give that a try.
Old 01-31-2010, 02:17 AM   #5
chevelle518
Re: Stripping Paint
any hardware store $4.00nper gallon
Old 01-31-2010, 09:09 AM   #6
63 & 64 Bowties
and a few others
Re: Stripping Paint
It's used in swimming pools, so any pool supply place will have it also. Some of them sell it in bulk, just bring your own container.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 02-01-2010, 11:26 AM   #7
slorio
slorio's Avatar
Re: Stripping Paint
Folks:
You might want to do some more research on this. I believe that muriatic acid is bad for the metal. I think the term for what is does is "embrittlement" if you want to search on that. Here's an example from a boat site:
Be warned, muriatic acid causes hydrogen embrittlement in carbon and alloy steel, cast iron, some stainless steels and aluminum alloys.
During the "pickling" process, the material takes on available hydrogen atoms from the acid. This causes what is called "hydrogen embrittlement." Hydrogen embrittlement causes the material to fracture along sheer planes more easily. Thus, the strength of the part is greatly diminished.
Hydrogen embrittled fasteners or parts under stress can fail suddenly without any warning.
I hope this is helpful.
regards,
Steve
New Orleans
slorio is offline   Reply With Quote
Old 02-01-2010, 11:37 AM   #8
chevelle518
Re: Stripping Paint
Originally Posted by slorio View Post
Folks:
regards,
Steve
New Orleans
You must of had a lot of time on your hand to research that in info. I have used on a couple times and there hasn't been any problem!!
Old 02-01-2010, 12:09 PM   #9
60ratrod
yes, i do
60ratrod's Avatar
Re: Stripping Paint
the biggest things that you need to watch out for hydrogen embrittlement in is your engine block, rotating assembly, heads, and anything else that either supports weight or takes extreame pressure and temperatures. but things like the tins on the engine are ok.
Old 02-01-2010, 02:53 PM   #10
chevelle518
Re: Stripping Paint
Thank you!!
Old 02-01-2010, 04:05 PM   #11
suville
suville's Avatar
Re: Stripping Paint
slorio is spot on! I worked in the aeromotive plateing industry for several years and we replated Pratt-Whitney Radial engine parts ,mil spec called for if I recall 400* for around an hour to: release trapped hydrogen from the pickeling process which is necessary in certain plateing operations, I refered to this very subject in a previous post about using acid to derust fasteners it is critical on structual fasteners sheet metal may not be a concern but you're taking a chance here.
suville is offline   Reply With Quote
Old 02-01-2010, 04:24 PM   #12
63 & 64 Bowties
and a few others
Re: Stripping Paint
Nobody has mentioned how the paint is going to adhere. You'd end up with a nice "sanded" surface, but what about the acid reacting with paint? Anybody know? I know you'd have to clean the surface before painting, but what's the chances you're gonna get every single molecule of acid?
Old 02-01-2010, 05:21 PM   #13
slorio
slorio's Avatar
Re: Stripping Paint
Thank you!
Regards,
Steve
New Orleans
Old 02-01-2010, 05:23 PM   #14
slorio
slorio's Avatar
Re: Stripping Paint
Suville:
Thank you!
Regards,
Steve
New Orleans
Old 02-01-2010, 10:23 PM   #15
60ratrod
yes, i do
60ratrod's Avatar
Re: Stripping Paint
well i work in the aviation community of the navy and hydrogen embrittlement is a big concern with aircraft parts, like landing gear braces. and this is from using isoprophyl alcohol atomized from spraying it from spray bottles. and we use a chemical stripper to do inspections on various hardened items like wing cross members and arresting gear tail hooks. and aircraft paint stripper we use is similar to muriatic acid. so if you aren't using it on a load bearing part or something that still needs its tensile strength or carbon content to hold any kind of pressure then go a head and use it, like on your engine tins, which don't maintain any serious amounts of pressure due to the evac system with the pcv valve and breathers.
Old 02-02-2010, 02:42 AM   #16
Heater63
Heater63's Avatar
Re: Stripping Paint
My 2 cents is there are better, safer, and gentler methods.
Example: Trans-Am racing '69- factory bodied mustangs were getting whipped by factory bodied camaros....one of the camaros was dipped in acid to thin the metal and lighten it! OK for a brand new body going one race season, but is that what you want to do to a 40 year old panel that you are trying to preserve???
just my 2 cents
292 + TKO500
Heater63 is offline   Reply With Quote
Old 02-02-2010, 10:22 AM   #17
lakeroadster
Re: Stripping Paint
Folks:
You might want to do some more research on this. I believe that muriatic acid is bad for the metal. ....
Hydrogen embrittled fasteners or parts under stress can fail suddenly without any warning.[/I]
As a Mechanical Engineer I have had actual hands on experience with Hydrogen Embrittlement. It is a problem for highly stressed components such as Grade 8 fasteners or aircraft components as 60ratrod eluded to above. It will not be a problem on sheet metal auto body panels.
And the Muratic Acid you buy at a pool supply place won't hurt the body panels if you use it the way Chevelle518 described in his first post.
I hope this helps.
lakeroadster is offline   Reply With Quote
Old 02-02-2010, 11:36 AM   #18
63 & 64 Bowties
and a few others
Re: Stripping Paint
I hope this helps.
Thanks John. That clears that up. Is this forum great or what? Free advice from a Mechanical Engineer. It don't get no better than that.
