Old 01-30-2010, 09:14 PM   #1
cjaj70
Heater Core
Do you pull the box the fan mounts to so you can change the heater core on a pickup with factory air?
cjaj70 is offline   Reply With Quote
Old 01-30-2010, 09:23 PM   #2
68custom396
Re: Heater Core
no there is a box inside the cab. if you take the glove box out you can see it really well and it will help getting the two screws from the box going through the firewall. you will have to take out the fender well also. there are i think 4 nuts that help hold on the a/c box (the box that the fan mounts to) those are studs from the heater box that have to come off. But the a/c box does not need to come off. hope that helps
68custom396 is offline   Reply With Quote
