Old 01-30-2010, 10:44 PM   #1
ag1972
ag1972's Avatar
taking the cab off
I am just about ready to take the cab off. I have saw where people use an engine hoist to pick the cab, but I cant find any pics of where they attached straps/ chains/ or whatever. If anyone has any pics I would appreciate it.
ag1972 is offline   Reply With Quote
Old 01-30-2010, 10:47 PM   #2
yote1234
yote1234's Avatar
Re: taking the cab off
just use one of these.. if you dont have a engine hoist..
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline   Reply With Quote
Old 01-30-2010, 10:54 PM   #3
phipp13
THE DAMN YANKEE
phipp13's Avatar
hey yote1234, you got an xtra 1 of those??? lol nice cab dolly, best 1 i've seen yet!
phipp13 is offline   Reply With Quote
Old 01-30-2010, 10:56 PM   #4
thelonerife
thelonerife's Avatar
I have used the cab/bed lift that a fellow board member sells the plans to. (rockrln)I made it and it worked well. Unfortunately I decided to sell it. I have also recently used a 4x4 with a bracket made to hold the 4x4 mounted to the hoist but its a little unstable but I did move the cab around by myself. I put the 4x4 right to the front of the door openings.
thelonerife is offline   Reply With Quote
Old 01-30-2010, 11:13 PM   #5
msgross
msgross's Avatar
Safer to get four buddies to help lift it off...
some have bolted a 2x6 to the hoist arm, others use chains to the floor, or the unit that is offered on the board as described above.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-30-2010, 11:18 PM   #6
AusTx68
AusTx68's Avatar
I'd have to agree. I used the engine hoist method to remove it and did so by myself. When I put the cab back on it was me and 3 other guys. It's much easier using the manhandling method.
Check this for photos of my cab removal
http://joes68.blogspot.com/2009/04/c...oval-time.html
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 01-31-2010, 12:57 AM   #7
69 longhorn
4 stout boys can handle that cab EASEY, & walk the rails In my younger days, I could hang onto my end of 600 lbs, but I only went 175 soakin wet.....it bites to get old! Now this 5' 9"old man goes 250(ouch!).Little bro ,still says that he be the bar tender, & I be the bouncer(you gotta love the respect). In a hard bar fight I need the "lil bioch" behind me(50lb pitbull, That curls up next to my ribs & sleeps every nite). trust me guys, that is the only dog that I have seen jump 6' up, Or have enough "smoke " to TAKE this old mans
pillow.....flop it up on the old mans back.....& go to sleep! You damn sure dont mess with the old man that she loves crazyAL
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 01-31-2010, 01:48 AM   #8
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Al, I got the first line of your paragraph. The rest of it I thoroughly enjoyed reading . Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 01-31-2010, 01:03 PM   #9
outback 1970
hey austx68 would you mind sending me the dimensions of your cab dolly,and any improvements you might have done if you had to do build a second dolly,any pointers are greatly appreciated
outback 1970 is offline   Reply With Quote
Old 01-31-2010, 04:05 PM   #10
Shaky
Six in a row makes it go...
Shaky's Avatar
It's light enough when empty that you can get pretty redneck about it. I used motorcycle tie-down straps to pull it from the rafters...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 01-31-2010, 04:53 PM   #11
AusTx68
AusTx68's Avatar
I pulled this photo from an older posting. Make sure to go with the 12" recommended. He initially went with 24" and it was too high. Mine is 12"
Old 01-31-2010, 08:46 PM   #12
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I put a pair of 2x4's together or a 4x4 thru the cab in the doors up front towards the vent window. It still leans forward a little bit because of the brake booster and a/c stuff.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 01-31-2010, 08:59 PM   #13
JimKshortstep4x4
I use two chain falls for lifting cabs off most of the time. Here is a pic of my son's Burb being installed back onto the frame using two hoists.
I have taken cabs off after they are stripped by bolting two 1x6 oak boards to the outriggers so that the cab rests on the boards which sit on the frame. With the wheels removed the cab can be lifted/dragged on the boards off the front of the frame onto a skid or cab dolly with two guys.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Last edited by JimKshortstep4x4; 01-31-2010 at 09:03 PM. Reason: posted different picture
Old 01-31-2010, 10:04 PM   #14
POPO1984
POPO1984's Avatar
thats sweet. i was thinking of running a chain hoist from my garage ceiling to lift my cab but i am worried the rafter may not suuport the cab.
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 01-31-2010, 10:25 PM   #15
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I put a 4x4 across 3 rafters and pulled a 4.3 v6 before.
Old 02-01-2010, 12:25 AM   #16
POPO1984
POPO1984's Avatar
i thought about that but the wife didnt want me putting holes in the gargae ceiling and i just had some friends come over to help me
South Houston
Old 02-01-2010, 12:37 AM   #17
gatewood
I built a set of A-frames out of 4 inch square tubing. It is a little pricey but they can be used for many other things. Good luck!
gatewood is offline   Reply With Quote
Old 02-01-2010, 08:51 PM   #18
doug70
Ok, took mine off today with a skid steer. Sorry no pictures.
Doug
68 CST 396, 60K original miles
70 Longhorn project
72 Stepside (150% complete)
67 Stepside project
71 RS Camaro 90% done
71 BB Corvette 50% complete
78 K5 project
doug70 is offline   Reply With Quote
Old 02-09-2010, 06:29 PM   #19
Slick67
Sofa King Crazy!!
Slick67's Avatar
Great tool, makes bed and cab removal a 1 man job in about 10 minutes.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 02-09-2010, 08:40 PM   #20
69 longhorn
If your wife is anything like mine,she wont care about the holes in the garage roof......its what it costs to fix it ,that starts the problem crazyAL
Old 02-09-2010, 09:23 PM   #21
mr48chev
mr48chev's Avatar
About 37 or so years ago I rented a house that has a two car garage as it's best and most redeeming feature. I poked a couple of holes in the ceiling and laid a 4x4 across several of the rafters with a chain looped though the holes. As far as I know that chain is still there. We swapped a couple of engines using a ratchet come along.
The new edition of Classic Trucks (April) shows a HF Gantry crane that they used to lift a cab but I have used the one I built to lift an swap Van roofs and cabs along with a lot of engines.
Roof off the doner rig.
Roof on the other van all by lifting the roof with the gantry and cherry picker and rolling one out an one under and letting the roof back down again.
That I beam is govt surplus aluminum with steel tubing for the frame so it isn't that heavy but sure is handy.
mr48chev is online now   Reply With Quote
