Old 01-31-2010, 12:26 AM   #1
Tinsmith
Diffrences In Bolt Pattern
Hey guys been a long time wallflower on here absorbing as much as possible. But I can't seem to figure out which models came with 5x5 bolt pattern or
5x4.75 bolt pattern. I have a 70 GMC originally 6 bolt but have just swaped in 71 5 bolt suspension. Everywhere that I have looked says that it is 5x5 but I have measured the wheel studs and it is 4.75 center to center. Were there two bolt patterns or am I measuring wrong?
Tinsmith is offline   Reply With Quote
Old 01-31-2010, 12:41 AM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Diffrences In Bolt Pattern
5x5 for the '71-72 trucks
IIRC 5x4.75 was used on cars.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-31-2010, 12:47 AM   #3
highperf4x4
Yeah 4.75 was for cars and S10 pickups.
You might have some Camaro rotors. If so, you need to make sure you have the right wheel bearings and calipers.
highperf4x4 is offline   Reply With Quote
Old 01-31-2010, 01:44 AM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Are you measuring like this for 5 lug? If not, that's your problem.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-31-2010, 08:32 AM   #5
cdowns
cdowns's Avatar
good illustration
Old 01-31-2010, 11:49 AM   #6
bigsnookmaster
bigsnookmaster's Avatar
X2
bigsnookmaster is offline   Reply With Quote
Old 01-31-2010, 11:56 AM   #7
Boog
laying low
Boog's Avatar
Chevy Mike's illustration looks crazy but that is the correct way to measure the bolt pattern size.
Once again: 5x5" for full size trucks
5x4.75" for cars and S10 trucks, blazers
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 01-31-2010, 12:21 PM   #8
Bruce88
Bruce88's Avatar
May be a full size bolt pattern picture you can print will help you figure out what you have. I generated one that can be found on my build thread (post #79) (read narrative for printing) http://67-72chevytrucks.com/vboard/s...=318544&page=4
From my understanding there is only three bolt patterns used on the 67 -72 trucks and there listed on the picture
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544
Bruce88 is offline   Reply With Quote
Old 01-31-2010, 12:57 PM   #9
Tinsmith
That is my problem then, Like I said I was going from center to center on the wheel studs. That makes me feel a lot better, not having to replace everything that I just did. Thanks Guys
