![]() Join Date: Nov 2008
Stock ride height
Hi everyone. I have a 1971 GMC C-15 that came with rear spring suspension originally and has been lowered via underslung leafs. I am trying to find out the stock ride height (measurement from ground to fender well lip or something similar) to be able to establish how much the truck has been lowered. I like the ride height as it is, but am wanting to change to a coil spring suspension. The stock measurement would allow me to order the correct drop coils for the new rear suspension. Any help would be greatly appreciated.
71 GMC C15 swb 71 K5 Blazer 72 K10 Woodhauler 89 Suburban 13 Duramax |
Re: Stock ride height
Well mine is stock ride height but it's a GMC with leaf springs and my tires are 295/50/15 so the measurement would be low. I might be able to get a measurement from the frame to the axle but I'd have to crawl around on the snow and ice.
Tot Roddin'
Before I lowered my '69 I took the following measurements on my coil spring suspension(running 235 75R15's):
Driver's Side Front: 33 1/2" Driver's Side Rear: 33" Passenger Sde Front: 33 1/4" Passenger Side Rear: 32 7/8" (From the ground to the center of the wheel arch on the fender/bedside.)
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 01-31-2010 at 12:40 AM. |
LMC use to have the measurements in their catalog. It was in the suspension section if memory serves me. There were two sections of the catalog that had drop springs and one had the info you were looking for.
I heard you guys got some snow yesterday. I appreciate it though. I am going to try 72BLCKBUTY's measurement and see what that gives me.
#6 | |
Thanks again
Yeah we got about 6 inches but the day before we got 1" of ice first. It's dirty business on the streets! The graders keep exposing the ice.
I seem to remember there being a height chart in LMC too, but I couldn't find it. I even pulled up some of my older catalogs with no results. I should've tried to call them, I've had decent luck with most of their technical people in the past.
Tot Roddin'
We lowered my '69 with a 4.5/6" drop kit and after dropping the truck I ended up with the following measurements:
Driver's Side Front: 28" Driver's Side Rear: 29" Passenger Side Front: 28 1/4" Passenger Side Rear: 28 3/4"
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
I got in a serious argument with my passenger vent window yesterday and forgot to measure. I am starting on the driver's side, so I will take a measure prior to jumping in tonight.
I appreciate the information. I hope this will lead to a clear cut spring choice for the new rear suspension.
#11 | |
Frequent Flyer
I've got the following measurements off of my truck...
Currently with the 4/6 Drop Front = 28" Rear = 28 3/4" Back when it had the 2/4 Drop Front = 30" Rear = 30 1/4" |
#13 | |
Thanks for the numbers
#14 | |
#15 | |
Frequent Flyer
Let me know if you need any more info or measurements. |
#16 |
So all you guys have half tons. Did the 8-luggers have the same stock ride height (mine is a 2wd)? Just wondering.
1969 C-20 Longhorn All original - 34xxx miles Planning a full frame off starting later in 2010 and through early 2011, and beyond... |
#17 |
Hmm.... good question?
