Old 01-31-2010, 03:41 PM   #1
scotts72heavyhalf
scotts72heavyhalf's Avatar
Thumbs down changing out the rear leafs?
I am thinking of switching from my stock rear leaf suspension to the coil over set-up, what will I need to do the conversion? Are all the holes already in the farme in a 72 C10 longbed? I found a posi set up but I dont really know what I am looking at.
Thanks guys
Scotts72C10
scotts72heavyhalf is offline   Reply With Quote
Old 01-31-2010, 05:20 PM   #2
scotts72heavyhalf
Re: changing out the rear leafs?
anybody?
Scotts72C10
Old 01-31-2010, 05:35 PM   #3
bad6772
Official Site Guitar Shredder
bad6772's Avatar
ttt for ya....Id like to know as well
bad6772 is offline   Reply With Quote
Old 01-31-2010, 07:01 PM   #4
MAK191
Not a difficult swap, but you will need a lot of parts. You will be better off finding a rolling chassis so you can take all of the little stuff. Long or short bed the trailing arm/ coil setup is the same. You should have the trailing arm crossmember already, but you will need the brackets that are connected to it that hold the trailing arms. There are alot of parts involved but they are easy to get. If you were closer, I have everything you need just laying around. The hardest part is the axle saddles. They need to be welded on. I'm not sure if your rear axle has the mounting point for the track bar, but you can just put on an aftermarket one that attached to the shock mount.
MAK191 is offline   Reply With Quote
Old 01-31-2010, 07:32 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I would go with regular coils personally, coil over shocks hooked to factory shock mounts have been known to rip the shock mounts off.
Old 01-31-2010, 09:00 PM   #6
scotts72heavyhalf
Thanks guys, I am going to look at the suspension tomorrow, the guy says he has everything for the swap and it has an eaton posi with 3.73`s
Scotts72C10
