Old 01-31-2010, 04:55 PM   #1
1971gmcshortbed
1971gmcshortbed's Avatar
Where to find rearmost crossmember replacement?
Hello suspension forum, is there anyone who sells a repalcement rear crossmember for 67-72? It's the rearmost one behind the fuel tank once you relocate it. Thanks for the help I apologize for my lack of search skills. Thank you 6772.
1971gmcshortbed is offline   Reply With Quote
Old 01-31-2010, 06:09 PM   #2
mbgmike
Re: Where to find rearmost crossmember replacement?
I think ECE? I remember a company that provided one with the tank. It was just a bent channel that could be fabicated but it would be easier to buy.
Here is a link to it. $45.00
http://www.earlyclassic.com/catalog.aspx
mbgmike is offline   Reply With Quote
Old 01-31-2010, 08:43 PM   #3
1971gmcshortbed
Thank you mbgmike, that is exactly what i'm looking for.
Old 01-31-2010, 10:07 PM   #4
Hart_Rod
Hart_Rod's Avatar
ECE sells the crossmember. I put one in my burb and one in my crewcab.
Hart_Rod is offline   Reply With Quote
Old 01-31-2010, 10:19 PM   #5
1971gmcshortbed
Thanks for the pic Rob it looks like it goes all the way back. And the hole for the lighting harness is there also. Good deal. It shouldn't interfere with bumper brackets right? I have leaf rear and I know brackets are different. Thanks 6772.
Old 01-31-2010, 10:27 PM   #6
Hart_Rod
Hart_Rod's Avatar
That's where I mounted mine. That's where it had to go to allow my FuelCellGuy tank to work. I guess you could move it forward if you wanted to. The top bolts are the rear most bed mounting bolts. The bummper brackets will bolt up, but it is very tight.
r/
