Old 01-31-2010, 07:10 PM   #1
nrb's70gmc
nrb's70gmc's Avatar
underhood noise alt or power steering pump?
ok quick question once again
im trying to find a noise under my hood i have got it down to the either the alt, or power steering pump pully.
it is a constiant noise and that is what it sounds like (bad bearing- i think) when i rev the motor up i cant tell if it gets louder because of engine noise, but win at idle it is constaint.
it does not sound like a rattle but more of like a squeel (dont know really how to explain it)
i can hear it in side the cab at idle and parking lot driving.
as far as parts i bought the alt in 2005-06 its a powermater 140amp and the power streeing pump was on there when i bought the truck. i have always kept proper fuild level in it.
anyone else heard this noise before? or have any advise?
1970 2wd 3/4 ton- 2004 crate 350 thorley tri-y headers-edelbrock performer eps manifold 600cfm performer carb, crane cams energizer cam,lifters, dual 2.5 magnaflows, mallory HEI, powermaster 140 amp altenator, griffen aluminum radiator.(8 MPG)
nrb's70gmc is offline   Reply With Quote
Old 01-31-2010, 07:20 PM   #2
BAD4X4
BAD4X4's Avatar
Re: underhood noise alt or power steering pump?
Stick a long screwdriver to your ear and then down to the ps pump or alt and should be able to tell which one it is. Hope this helps.
1972 Cheyenne K-30 6"lift {502 PROJECT}
1972 Cheyenne K-30 8"lift 454 450hp {Ol'Blue}
1972 Cheyenne K-20 Custom Stretch 6" lift 454
1972 Custom Deluxe K-20 4" lift
2007 GMC Crew Cab Diesel 6"lift {The Tow Rig
2017 Ford F-350 Crew Cab 6.7 6"lift (Wife's)
1977 El Camino SS Grandpa baught new
1986 K-30 Crew Cab 502
1955 Chevy 2-Door gasser 454 550hp{project}
1956 Chevy Bel-Air 2-Door hardtop 572 700hp
1979 Ford F-350 All Original 4x4 (Wife's)
BAD4X4 is offline   Reply With Quote
Old 01-31-2010, 07:26 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
or loosen/remove a belt and fire it up. if the noise is gone, then the pully that is no longer spinning is the bad one.
Old 01-31-2010, 07:38 PM   #4
nrb's70gmc
nrb's70gmc's Avatar
i did do the screwdriver sound test the alt did not sound bad the pump did not sound all theat bad either im going to go pull a belt and see
Old 01-31-2010, 07:42 PM   #5
gkesseru
gkesseru's Avatar
I once had a similar noise that I couldn't find. An older mechanic told me that antifreeze on a belt can make a ticking sound. Sure enough, a new belt cleared up the problem.
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 01-31-2010, 07:50 PM   #6
nrb's70gmc
nrb's70gmc's Avatar
ok i just found out that its the power steering pump so, what next? can the noise be a bad belt? or is it a pully problem? thanks mr.longhorn man
Old 01-31-2010, 08:00 PM   #7
junkyardjohn
junkyardjohn's Avatar
I've got a pete jackson gear drive timming set (the noisy one) in my daily driver, & have had several complete strangers (always helpful & sincere) tell me at a light or in a parking lot........ Hey buddy.... Sounds like your p.s. Pump or alternator has a bearing going. I love that whine. I've had water pumps make noise too, but if you grab the fan & try to wiggle it, you can usually tell if theres any slop in the bearing. john
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 01-31-2010, 08:05 PM   #8
nrb's70gmc
nrb's70gmc's Avatar
ok im confused, i put the belt back on and started it, no noise / maybe a loose belt?
Old 01-31-2010, 08:07 PM   #9
nrb's70gmc
nrb's70gmc's Avatar
gear drives sound cool worn out parts sound like a POS
Old 01-31-2010, 08:30 PM   #10
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Maybe so, but if the noise comes back, try a new belt.
John! Good to see you posting again, I thought maybe you fell off the face of the earth after you left Nevada!!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 01-31-2010, 10:30 PM   #11
Longhorn Man
No doubt man, I thought you were gone too man. March of 07 till jan of 10... good little break there.
