Help!
I'm trying to find TDC on my inline 250 so that I can adjust the valves, but a) i've never done it, and b) there doesn't appear to be a bolt to put a wrench on in order for me to turn it...there's just the harmonic balancer w/ the three holes and then the hole in the middle, but nothing attached to it...I've ready you can tap the ignition and get the rotor pointing the right way, but if they dizzy isn't put in that way then it wouldn't be correct...Please help me out...how can I turn this thing by hand?
If this is a rookie question, I'm sorry, but I've searched and read and tried and can't get it done...do I need to take off the belts or anything? I also read that you can put some penetrating oil into the spark plug holes to loosen it up a bit...maybe give this a shot? Thanks in advance! I need the help! Lance |
Re: Help!
the 3 holes should be threaded and you can put in some long bolts that fit and use either a long screw driver or a pipe or somthin to turn over the motor also lossen the plugs it will make it a lil easier to trun over
and also remember 15-36-24 this is your fireing order good way to remember that is the rite time 2 get marred 15 to young 36 to old 24 just rite sorry auto mecanics teacher tought me that cant forget it another thing you need to remember your corosponding cylinders 153 624 other words 1 & 6 are up at the same time and same for the others So when #1 cylinder is on compression # 6 is up on exhaust the exhaust valve will be closing and the intake will just start to open, #1 cylinder can be adjusted at this time. When #5 cylinder is on compression # 2 is up on exhaust the exhaust valve will be closing and the intake will just start to open, #5 cylinder can be adjusted at this time When #3 cylinder is on compression #4 is up on exhaust the exhaust valve will be closing and the intake will just start to open, #3 cylinder can be adjusted at this time. take your time and it will turn out good, and keep them adjusted when i got my car it idoled like diesel truck lol
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin 79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s 81 mercedes 300d 25 MPG 77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded" 73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091 '77 chevy trucks. built to stay tough. life is short build a hot rod ![]() Last edited by big10ratrod77; 01-31-2010 at 09:05 PM. |
Re: Help!
Great! That helps. Any clue of what size bolt it takes?
Re: Help!
ide just do it by trial and error and fyi it probly wont be fine thread
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin 79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s 81 mercedes 300d 25 MPG 77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded" 73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091 '77 chevy trucks. built to stay tough. life is short build a hot rod ![]() |
