Old 01-31-2010, 08:12 PM   #1
1971ChevyTruck
1971ChevyTruck's Avatar
Fuel Cell Venting Question
My dad has a Jazz fuel cell mounted behind the rear axle. It has an self venting cap on the top. He is about ready to do a rear marker light gas filler and I noticed the S-10 fuel filler has a vent pipe. Does he need to use that since the tank is already vented?
1971ChevyTruck is offline   Reply With Quote
Old 01-31-2010, 09:47 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Fuel Cell Venting Question
If he's using the rear filler, then I'm assuming he won't be using the vented cap anymore, soooooo, yes you will need to use the vent. Of course, this all assumes I understand your question, .
Hart_Rod is offline   Reply With Quote
Old 01-31-2010, 10:00 PM   #3
1971ChevyTruck
Thanks, but here is the cap that I am refering to and not a locking cap. I should have posted a pic, sorry
Old 01-31-2010, 10:12 PM   #4
Hart_Rod
Hart_Rod's Avatar
No worries, . I would still get a brass fitting and install in the same location and run it over to vent on the S-10 fuel filler that you are going to use. That way, if it ever overflows through the vent, it will go back in the filler back to the tank....
