01-29-2003, 06:36 PM | #1 |
Clutch linkage question
I have a 69 c10 it had a 292 with a three on the tree. The six cyl is out and I have a 350 for it. Im using the same tranny. Will the Clutch linkage work from the 292 or not. Can you tell me what I need to get. Thanks Brian Wolf
01-29-2003, 06:51 PM | #2 |
Fabricate till you "puke"
If you are mounting in I 6 position with the sb, the 250 eng stands will work(you will need to change the pass side stand). Mounted in I6/250 position with my sb, here is what worked for me.......I used all of the v8 clutch linkage, & instead of the bolt on bracket/pivot ball , I used a screw in pivot ball in the foward hole on the block. Then the bell crank was set up perpendicular with the eng, & the holes were redrilled for the frame bracket (again the v8 pc). The lenght of the bottom rod then had to modified. set up like that , I ran a set of 69090 Hedman headers, & all the linkage cleared. I couldnt say about the column shift linkage, as I ran a floor shifter. Good luck.....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
01-30-2003, 12:18 AM | #3 |
Brian, If you are in Bismarck some time, stop over at my house. You can look at my 327 clutch linkage set up if you want. I've got my engine out for a rebuild right now.
Drop a PM sometime.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
01-30-2003, 01:44 AM | #4 |
linkage
Sure I will be in Bis on the 30th. If your around I would sure like to step by and take a look. I always wanted to find some guys in Bis that are into our style trucks. You could give me your phone #. Then we could set up at time and date to meet.
....Brian wolf |
01-30-2003, 09:27 AM | #5 |
Sure, I'll be around.
I sent you an e-mail with the info. Tom.
05-28-2003, 04:16 PM | #6 |
Progress = 0%
Hey Brian,
You still owe me $60.00!!! Pay up!
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
