Old 02-01-2010, 01:01 PM   #1
mike16
dual exhaust questions
I have a stock 72 long fleetwith a 3spd and coil spring rear. It came factory with a single exuaste. I am debating putting duals on it but only have a set of brackets on the driver side for the single.
My questions are:
what are people paying for dual exuaste systems?
what do you do for brakets on the passenge side?
anybody run into problems using the 2 quart Fram pf 373 style filter and thier exuaste clearance?
mike16 is offline   Reply With Quote
Old 02-01-2010, 01:54 PM   #2
mrein3
mrein3's Avatar
Re: dual exauste questions
My questions are:
I did and would go again with the dual set-up advertised in LMC. It is drop-shipped from a place in MN called Heartthrob Exhaust. http://www.heartthrobexhaust.com/
I ran into the same thing. No bracket on the passenger side. I used a generic exhaust hanger from NAPA. Every other part I needed for the system came in the box.
My application is a 4x4 - center dump verses angle dump manifolds. You didn't say what your 72 is. The LMC 4wd kit fit around my 3-speed manual which later was swapped out for a th-350. The kit fit both.
Oh and it is around $200 if I remember correctly.
I don't work for LMC or Heartthrob Exhaust
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 02-01-2010, 04:06 PM   #3
rsavage
rsavage's Avatar
I just ordered a manifold back dual set up with stock exits from Summit made by Hooker Headers for my Burb. It was $203 shipped. I'll still need to get two turbo-type mufflers which will be another $50. I'll let folks know how it fits once I receive it Wednesday. I looked at the similar offering from LMC that came with mufflers for $210 Plus shipping, but I didn't find an application for a 2wd Burb, only 4wd. I'm sure with shipping it will be at least the same.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 02-01-2010, 05:23 PM   #4
Wrenchbender Ret
I get them built & installed at a muffler shop for $300.
Wrenchbender Ret is offline   Reply With Quote
Old 02-01-2010, 05:30 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
240 dollars from manifolds to the bumper including the tips. No mail order system would work for my truck since it is lowered pretty far. The muffler shop guys build the hangers for the second side.
Old 02-01-2010, 08:40 PM   #6
COACHMEASON
Keep On Keepin' On
COACHMEASON's Avatar
Re: dual exhaust questions
My muffler shop charged 360 for pipe and flowmasters from the headers and dumped behind back axle...
07 Avalanche Z71
92 Mustang 5.0 GT (Triple White w/ 53,000 miles)
72 SWB Chevy w/ PS, AC, 350/350
Current Project ....In paint shop getting body/paint work done (Corvette Velocity Yellow)...
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
COACHMEASON is offline   Reply With Quote
Old 02-01-2010, 09:49 PM   #7
crushermechanic
crushermechanic's Avatar
paid 400 for mine. 2 1/4 from headers turned out behind rear wheels with flowmasters at muffler shop.
crushermechanic is offline   Reply With Quote
Old 02-01-2010, 10:08 PM   #8
bigguy69
dazed and confused
bigguy69's Avatar
YouTube- The 63 farm truck with new exhaust
it sounds good, if you dont mind me asking what kind of mufflers are those?
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 02-01-2010, 10:20 PM   #9
Tx Firefighter
Brockman Mellow Tone steel packs- 22 inchers
http://www.brockmancustomparts.com/page2.html
The audio is poor on that clip. They actually sound outstanding, a real raspy sound. I get compliments on them every time I drive it. I can't say that about any other muffler I have ever run.
Old 02-01-2010, 10:28 PM   #10
Beatcoaster
69 Fleetside
Beatcoaster's Avatar
I just ordered the Pypes Street Pro system with X-pipe from Jegs for $400 - All the youtube videos sounds awesome, we shall see if my vortec 383 sounds just as good...
Beatcoaster is offline   Reply With Quote
Old 02-01-2010, 10:30 PM   #11
69 longhorn
I have $325 in mine including headers(Hooker comps). The system was built to my specs, I did it on a Sun afternoon, when I worked in the muff shop. the headers were a buck 40, the slightly used 50's Flows were a freebe, & the old man runnin the shop was pretty easy on pipes/hangers, & the use of his shop.....the stainless tips that are poked through my rear bumper cost almost as much as 20 plus ft of pipe ,hangers ,&clamps under that old Longhorn. I went Percy alum on the collector gaskets, & opted for a set of weld rings to mate to the headers(40 bones for both pcs). figuring 85 a pop on the 3 chamb flows ,all in all, it would have been a 600 dollar shop job (headers,muffs,pipes/hangers & tips). 2 1/2" from the headers to the back ,with H pipe, & its all tucked nice ....sounds sweet crazyAL
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 02-02-2010, 01:28 AM   #12
highperf4x4
2.5" from the manifolds to the back and 36" glasspacks with 2.5" cores. 290.00 at the muffler shop
highperf4x4 is offline   Reply With Quote
Old 02-02-2010, 06:53 AM   #13
Phlebmaster
Phlebmaster's Avatar
Smile Re: dual exhaust questions
I just did a swap on my 72 from single rams horn exhaust to Mr. Gasket headers with glass packs similar to highperf4x4. I have to say that I like the sound of the new exhaust much better.
But I like the price...I traded a 400 crank that I traded for something else and an old Q-jet carb for my set up.
Before swap.....
After swap.......
Thanks, Aaron
Life is about making dreams come true, stop dreaming and make life happen.
64 GMC Project MY_YOUTUBE_VIDEOS To keep an opened mind- speculation is devine.
Assumptions always lead to a dead end!
Phlebmaster is offline   Reply With Quote
