02-01-2010, 03:00 PM | #1 |
heater ?
my heater box and core are broken... do i need to hook up the hoses to a new heater box and core or can i go directly from the enigine to the radiator and bypass the heater? any advice? this is my first time working on cars
02-01-2010, 03:08 PM | #2 |
Redefining LowBudget
Re: heater ?
yep you can just make a loop
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
02-01-2010, 04:30 PM | #3 |
Re: heater ?
and what does that mean? sorry i am a fool lol.... do u know where i might find a pick to walk me through it? thanks for your help. makes my life a lot easier
02-01-2010, 04:37 PM | #4 |
Re: heater ?
What they mean is take a lenght of hose from your water pump and hook it to the intake manifold fitting, but I belive one is 5/8" and the other is 3/4", so you may want to change out one of the fittings to make both the same diameter. They should both be 1/2" NPT
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
02-01-2010, 04:44 PM | #5 |
Re: heater ?
so it doesnt make a difference? are there pros vs. cons for doing it that way?
02-02-2010, 08:16 AM | #6 |
Re: heater ?
Since we're talking heaters I thought I'd jump in. Right mow mine is bypassed just like discussed. It sure would be nice to have heat since it's 27 degrees in VA right now, but it's really not anywhere on my list. My fix for now is a small space heater attached to a extension cord and electrical timer that kicks on about 30 minutes before I leave for work so my windows defrost. If anyones curious according to the warnings on those electrical timers you shouldn't use them with extension cords or space heaters.
