02-01-2010, 06:26 PM | #1 |
I'm in the ROCKWELL CLUB !!!
Well kind of......... Is there a Rockwell Club . If so maybe I can be a member.
Let me know!!!!
1972 K5 Build - plans - LS3-6L80e-One Tons..... 1971 CREWMAX Build.....at body shop for couple more years |
02-01-2010, 07:13 PM | #2 |
Re: I'm in the ROCKWELL CLUB !!!
Cool, what your you going to do with this? The pulling or will you use the other one for that?
72 gmc 2500 2wd drive convert My 72 thread http://67-72chevytrucks.com/vboard/s...d.php?t=346712 THe other truck, wheeler 69 1/2 4x4, yellow and rusty. http://67-72chevytrucks.com/vboard/s...d.php?t=350300 |
02-01-2010, 09:27 PM | #3 |
Thank god when I first read the title I thought you were going to destroy the 71
1949 Five Window, 1973 Step Side, 2000 Z71 |
02-02-2010, 08:48 AM | #4 |
WELL, the way I talked the queen into it was a promise to limit me tearing up the 71 (this doesn't mean it wont see a pulling sled at all just not as much)
The plan is for MUD!!!!!!!!!!!! and maybe a couple BACK to BACKS !!!! Ghetto - Might need two spots for next years!! hahaha Now I need to learn somethings about Rockwells.................... Any help from you rockwell guys is appriciated
02-02-2010, 09:40 AM | #5 |
Dont use the rockwells for back 2 back they won't hold up to a hop!
02-02-2010, 11:54 AM | #6 |
ROCKWELL 5 TON CLUB !!
YEAH!!!!
yes there is a club,kinda.Lol ive done 2.5's and now 5tons . would be glad to help however i can.
1970 K5 "ON THE ROCKS" PROJECT:500hp 6.0 fuel injected. 2wd sm465 trans,t136 2.5 ton transfercase,5ton rockwells with 9.34 gears,custom wheel disc brakes,full hydro steering20+" OF LIFT AND 67/35/25's..67" tall TRACTOR TIRES.."THE MUD SLUT!!" MY BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=221935 1997 TAHOE,SAS D60 14B,5:13 DISC BRAKES,CROSSOVER STEER,HYDRO ASSIST,42 IROKS HINT:NEW NAME "K5ontheROCKS!" |
02-02-2010, 06:03 PM | #7 |
Ghetto, I planned on using some traction bars similar to the ones on the 71. Would think they could help prevent it????
Tallhoedude - Man do I ever have questions.......... It currently has crossover - want to change to at a minimum hydro assist but maybe full hydro? Is there a chaep orbital valve to use for full hydro or should I just tap my current steering box and run hydro assist? What type of cylinder? Will any from the tractor supply work? I have read multiple treads over on Pirate but never really get clear answers....... Is one rear pinion brake sufficient for mud holes? I have a bunch more but will just start with those......... Thanks guys
02-03-2010, 09:32 AM | #8 |
fire away,ill help where i can.
first,have you been here?: http://chuckstrucks.iforumer.com/ind...m=chuckstrucks that is the mecca of rockwells!! forget about pirate4x4.com second,crossover will be more $ than full hydro,may require some custom parts or fab.and isnt needed for a mud truck i got my orbital from ebay,rebuilt for $200,everything else(column,fittings,hoses,ram,)are off the shelf at tractor supply.running a gm medium duty resivour with filter $20 from junkyard,and a used trans cooler,free. i did some research at chucks site to figure what size orbital to get then found one on ebay. i use the stock ps pump,but want a little more flow so im gonna mess with the shims and springs in the pump soon. im about 5 turns lock to lock,doesnt do too bad on the street,not like ive done it much ,but....it works,cheap. as far as pinion brakes,yes one is fine,i have 2,but lots of mud trucks run 1 on the rear. any more? let me know
02-06-2010, 12:29 AM | #9 |
Do you have the part number for your orbital valve. I am thinking about running a 2''x10'' ram from teh tracto rsupply store like you mentioned.
Alos, I have Hydroboost brakes, will this be OK or not?? I started to tear into the truck today and it looks like I have a passenger side wheel bearing that is taosted, I can barely spin the wheel. I will be taking this apart real soon. Where is the cheapest place to buy gaskets and seal. I will probably just clean the bearings and reuse if possible. Thanks again for the help, love your build! Is there a link for wheel bearing replacment, I am still waiting on ChucksTrucks to confirm my registartion, it appears something might be wrong it has been a couple day. I Need to look into this. thanks again
02-06-2010, 09:50 AM | #10 |
Junior Member
go to www.boyceequipment.com i have 2.5 ton millitary reares in 2 of my trucks and i get everything i need for them and any other rears out there, they have everything you need
02-08-2010, 11:44 AM | #11 |
boyce is usually a little high priced.try:
http://www.bambambiguns.com/ ive also had good luck with green gem army surplus.
02-08-2010, 11:47 AM | #12 |
i was able to clean and reuse a lot of my brgs,after all,its just a mud truck,so what if theyre a little loose.
the TSC ram will work great. im tryn to find the exact #'s on my orbital for ya. hydroboost shouldnt be any issues,couple extra hoses maybe.
02-08-2010, 05:46 PM | #13 |
Talked to a buddy and he said the same thing, as long as they are not totally shot just pack as much grease as possible and reuse them. My pass. side wheel is very hard to rotate so that might be shot ?? We will have to see. He also said he would just use RTV instead of spending the money on gaskets and he also said the use the bearing to remove the sela from the back side and the seal might even be able to be reused?
I do have to buy boot since there are none there currently. I hope tonight to get it running and movable the I can tackle the front end this weekend Is there a on-line place for detailed instructions on these things that can be downloaded so I dont have to get a manual. ( I am cheap !!!!!)
02-09-2010, 10:54 AM | #14 |
i agree on the rtv,the only seals i buy are the axle seals and boots.
bambam has all that stuff. look on steelsoldiers.com , you will find plenty of pics and instructions
02-09-2010, 09:24 PM | #15 |
Chevys Kick A$$
Wow that's a sweet looking truck I like it. Gonna be a blast in the mudd for sure
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
02-21-2010, 11:38 PM | #16 |
TALL
Any luck on the orbital valve number thanks
03-01-2010, 04:31 PM | #17 |
hey man,cant find numbers on the damn orbital.
ill get some pic of it this week and see if i can find the link to where i bought it. ive heard a few guys lookin at heavy equip,findin one with about the same size cyl they run and just go with the orbital.seems like it would be a lot of swappin boxes till you go the rate you wanted. any luck ever gettin on chuckstrucks.net site?
03-02-2010, 12:42 PM | #18 |
I also heard that trying to mix and match valves with cylinders takes some investigation. I have found a couple valves on some various 4x4 places that are around $350 for the valve and spline adapter. Just trying to decide if I want to try and run hydro assist or just go full hydro.
Hydro assist would be pretty cheap if I tap my ps box, then all I have to buy is a cheap surplus ram and hoses. Full hydro I am debating on if I want to run a single action cylinder or a double action. I beleive I can piece toget the single action for about $200-$300 cheaper but in the long run it is all going to run about $1000 if I have to get a new ps pump, orbital, cylinder and so forth. Just cant decide, really dont want to spend the money on the hydro assist if in the long run decide to go to full hydro??? Any suggestions Chucktrucks site is still not allowing me to log on, trying to contact an admin. thanks
03-11-2010, 03:34 PM | #19 |
Finally able to get on ChucksTruck webpage and post.
I still have had no luck on finding some used Hydraulic Steering stuff. If anyone here has or knows of some shoot me an email or something thanks guys
