Hello, can anyone tell me what the difference is between drop coil springs? Here is my situation, i have a 66 Chevy c10 SWB but I replaced the front suspension from an 82 chevy c10 and was wondering should i buy the Coil springs for an 82 Chevy or for a 66 Chevy? not sure if it goes by the weight of the truck or by the diameter size of the coils springs. If someone could help me out here i would really appreciate it.
Thank you all in advance. |
Badass
Re: Coil springs help!!
it should be around the same weight. just find (73-87)3/4 ton springs and cut them down till you like where it sits
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
Well i want to purchase 3" front coil springs but when i look on line they show from 60-73 then i see from 73-87 then i see from 60-83. could i just buy from 60-73 eventhough i have a front suspension from an 82 chevy truck?
thanks |
if you have the 82 front end your going to need the 73-87 parts. the older springs are going to fit in the pocket correctly.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
id use the 73 87 springs. theyll fit in the pockets correctly. I ve heard of people using the OE springs (your 66 springs) and them getting a popping noise from the springs moving in the pockets sometimes
1967custom |
Thank you all but i just found a forum here where some one used coil springs from a 70's model Chevelle and dropped the back about 3 or 4 inches, so i think that is what im going to go for.
