Old 02-01-2010, 08:13 PM   #1
NZSquare
NZSquare's Avatar
Sleeve bag questions
Hi All,
I want to redo the back of my truck, its an 82 longbed c10 and Im running a 3-link and 2" c-notch with contitech 2500lb bags behind the rear axle.
Due to the current shock/bag setup Im only getting 5.5 " of travel.
Im going to a 7" bridge and want to keep the 3 link, and behind axle bag setup, but maybe go to sleeve bags as I hear they ride good and seem to get pretty good travel.
What sort of bags should I go for ? I want about 8" of travel out of the new setup and was looking at firestone bags. I read on here that they need to be travel limited but is there anything else I should b considering before buying ?
thanks in advance
NZSquare is offline   Reply With Quote
Old 02-01-2010, 08:30 PM   #2
NZSquare
NZSquare's Avatar
Re: Sleeve bag questions
heres what Im on about, Plan being to keep the extra crossmember and lower bag mounts, and cut the uppers out to allow for the sleeve's is theres space.
Old 02-01-2010, 08:39 PM   #3
PBFAB.COM
PBFAB.COM's Avatar
We used the F9000 on all our rear kits. Mounted behind the axle like you have pictured you will get right at 7.5" of travel. You do need to have the bag limited by a strap or shock (otherwise it will tear the bag apart).
I think you have a good plan.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 02-01-2010, 09:22 PM   #4
NZSquare
NZSquare's Avatar
Thanks for the snappy reply Nate, you were just the man I was hoping might answer.
Ill get them on order.
Old 02-02-2010, 08:28 AM   #5
jlaird
jlaird's Avatar
Does anybody have any experience with the airlift sleeve bags? The reason I ask is because the firestone bags compress to 4.5" whereas the airlift bags compress to 2.8". The firestone bag will not allow my truck to get as low as it could.
airlift is the first picture.
jlaird is offline   Reply With Quote
Old 02-04-2010, 12:18 AM   #6
jwalk
What was I thinking?
jwalk's Avatar
Not meaning to highjack this thread,but I was just wondering if I have to run a sleeve type bag on the back of my dropmember, or something like a slam bag? I just don't like how the firestone sleeved bags are plastic or some kind of composite. Should I not worry about the firestone bags and just use them?
Thanks, Justin
jwalk is offline   Reply With Quote
Old 02-04-2010, 09:40 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by olskool59delivery View Post
..... Should I not worry about the firestone bags and just use them?
That's what Nate of Porterbuilt, and Tony of Ride Tech recommend.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-04-2010, 11:48 AM   #8
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
They are fine.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 02-04-2010, 11:55 AM   #9
xJoey Dubsx
xJoey Dubsx's Avatar
Airlift Dominators get some good lift for a 2600k bag.... I don't like sleeves for a main source just due to looks.
[CENTER][FONT="Arial Black"]-------------------- Joey Dubs --------------------
2000 Dakota - Bagged, Shaved, and more
2003 Ram - Fast, and perdy
1951 GMC Stepside - All apart, like a puzzle.
xJoey Dubsx is offline   Reply With Quote
