![]() Join Date: Oct 2009
Replacing Defrost lever on 71 K20
The current lever is there but it's not doing anything. I have the replacement lever and cable (if needed) from LMC. Any suggestions or pointers before I start?
Murphy |
Re: Replacing Defrost lever on 71 K20
Getting ready to start this job. I'm going to replace the fan switch and all the hoses!!! I went with the new plastic style, not OEM. I'm going to pull the bench sit out for room. Any pointers would be greater appreciated!
The Older Generation
The best way to work on them is to remove the control head and cables. There are two machine screws under the edge of the dash you need to remove to get the control head out. You have to unplug the connector from the switch on the right side and unplug the light socket from the left side in the back. The cables are held on with small screws and push on clips.
Here is a thread where I posted some pics. http://67-72chevytrucks.com/vboard/s...d.php?t=319890 LockDoc
Thanks Loc Doc!
I had to order a flexible HP oil line. The PO put a nice S/S tube right through one of the hoses. I can't get it to move around the hose, so I have to replace it. I have a ground problem in my cluster (everything flashes when the turn signal is on), so maybe I can do all three at the same time. The top lever is broken (part in hand) and I bought all three cables. I like the pointers on lubing the cables. I have to replace the fan switch while I'm in there. |
Re: Replaced lever now onto the rest of heating system on 71 K20
Finally have all the parts and some time to start replacing the hoses.
While I'm doing that, I need to find out why the heat is always on! The aftermarket A/C is disconnnected (That will be later this summer). Also, when I open the vent (kick plate) on the drivers side, the passenger side doesn't do anything. I see it has a vacuum hose and valve. Is that tied into the A/C or is it on a separate system? I found a great guide - Vintage Air - 29 pages of detailed pics and decent step by step directions. Thanks in advance |
#6 | |
Yes the pass. side air vent is controlled by the air cond. I don't know a lot about the air setups but I would say that what ever controls the hot water to the heater core isn't working and it isn't shutting off the flow of hot coolant to the heater core. LockDoc
On the vent. I understand now the function for "Fresh Air" vs. inside air. Once I get the A/C hooked up, I don't want fresh air, I just want to freeze my tail off when it is HOT! So, I see I can add a manual lever to the vent just like the driver's side. OK everyone, what are your thoughts?
(God knows what kind of shape the A/C is in, I'm sure it's a major project!!!) Keep the vacuum control or go to manual on the vent? |
