Old 02-01-2010, 08:51 PM   #1
NICKG116
NICKG116's Avatar
250ci Anti-Freeze pouring where tranny/engine meet!??!
Ive searched the whole internet and i cant find nothing...I just got this truck and it replace all the hose etc...and when i put anti-freeze in the raditor it pours out a hole in the flywheel cover...is there a freeze plug on the back of the motor? 68 250ci c10...thanks guys!!
NICKG116 is offline   Reply With Quote
Old 02-01-2010, 09:20 PM   #2
mbgmike
Re: 250ci Anti-Freeze pouring where tranny/engine meet!??!
I don't remember. I should but getting old.
go here he is selling a 250 maybe he can look
http://67-72chevytrucks.com/vboard/s...70#post3770870
mbgmike is offline   Reply With Quote
Old 02-01-2010, 09:22 PM   #3
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Yes there should be two if my memory serves me right.
Camaro_nut2001 is offline   Reply With Quote
Old 02-01-2010, 09:26 PM   #4
NICKG116
NICKG116's Avatar
Thanks...the only other thing would be a cracked block right?
Old 02-01-2010, 11:12 PM   #5
Dark Knight
Dark Knight's Avatar
It shouldn't have a cracked block if you kept the correct amount of antifreeze in it. That doesn't mean that the PO did though... Anyway, there's a big freeze plug behind the bellhousing and a smaller one next to it. The small one is directly behind the camshaft, so I doubt it's the one leaking. (Well I guess if it's behind the camshaft there would be oil behind it, not coolant. DUH!) What happens is when rust builds up behind the freeze plug, it develops pinholes. These can go unnoticed and eventually get worse. You can just pull your tranny, pop a new freeze plug in, and you should be good to go!
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS
-1983 Chevy Silverado C1500- 383 stroker, TH400
-1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears
-And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket
"The only thing we have to fear is fear itself." -FDR (and maybe rust too)
You've gotta be able to stop and steer before you can go fast!
Dark Knight is offline   Reply With Quote
Old 02-02-2010, 12:49 AM   #6
69 longhorn
If my old memory serves me right...Yes you are right on the problem If it were mine, I would pull ALL the clutch/flywheel pcs & check it......I doubt that you cracked it, more likely a rusted out core plug. If the block is cracked, you will see the line of rust, running to the core plug . best of luck,crazyAL
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 02-02-2010, 09:48 AM   #7
NICKG116
NICKG116's Avatar
thanks guy...when i got the truck it was at a shop gettin worked on and the man passed away...its been sitting for a year or 2 without water or antifreeze....the shop installed and brand new radiator..gas tank..fuel pump and water pump and pushed it out side...i put a new manifold gasket and a battery and it fired right up old plugs and all..runs awesome.everything works on this truck all the lights wiper everything
