What do i do?
Ok my motor has been sittin a while and its finaly time to put the motor in but i notice it has something in the water pump port. I already no its going to be bad so i poke my finger around in there and its a wasp nest.Now im stuck i dont no how to get it out any suggestions?
Re: What do i do?
vacuum? fitting brush?
Re: What do i do?
for a future heads up. If you know its bad. You should not poke it with your finger. Why not wash it out with a hose?
BAD BOW-Silverado XST
Re: What do i do?
First use a vacuum. Second, a water hose with plenty of pressure. Use the water hose on the opposite side of the nest. If both holes have nests, well use the hose on the smallest nest. Use a long welding rod to break up the nest.
Use a priming tool to oil the engine. |
