Old 02-02-2010, 01:37 AM   #1
streetgliderac
Z Bar
Is there a difference between 6 cylinder and v8 z bar? How bout clutch rod coming out of firewall? Moving my sbc from rear position to front and think i need to change clutch linkage. Anyone know where i can get the piece of bent flat bar with two holes and pivot that attaches to block? Thanks. This is only my second post i think so pardon the to the point verbage. not much of a writer.
streetgliderac is offline   Reply With Quote
Old 02-02-2010, 01:47 AM   #2
BAGNDRAGIT
Just Not Low Enough!
BAGNDRAGIT's Avatar
Re: Z Bar
as far as i know there is a difference in the 6 and 8 cylinder z-bar, or bell-crank as some refer to it. and im not sure on this but i thought the front position was for BB applications, i could be wrong , someone will chime in with the answer.
and i know you can get a bell-crank from http://www.grumpystruckparts.com/index2.ivnu
NEED ELECTRICAL HELP? ASK ME!
67-72 Full Wiring Diagrams
Lots Of Info, TAKE A LOOK
1967 Chevy C-10 Shortbox Bagged 327 4spd
Previous:
1971 Chevy C-10 Short Sep I6 Auto (Traded)
1973 Chevy C-20 *THE REDNECK BATTLE TRUCK*
2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P.
1969 Volkswagen Bug
This is my first meeting, I have a horsepower problem.
BAGNDRAGIT is offline   Reply With Quote
Old 02-02-2010, 09:05 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Z Bar
Yes the z bars are different. You should be able to get all the proper pieces you need off the parts board. When I need something like that I usually send teeitup a message. He has everything.
Old 02-03-2010, 05:43 PM   #4
dan468
dan468's Avatar
Re: Z Bar
Is the bar that mounts to the block the same bolt pattern for SBC and BBC?
Thanks,
Dan
68 C-10
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=414699
dan468 is offline   Reply With Quote
Old 02-03-2010, 06:52 PM   #5
michael bustamante
michael bustamante's Avatar
Re: Z Bar
nope the bb and the small block pieces are different. I just sold the one for the sbc with the ball on it. as for the z bar, like tx says, they are indeed different. I bought a truck where they cut off the arm and bent and relocated it by welding, looked like crap but I guess it worked until they fried the clutch!! :0
1967custom
michael bustamante is offline   Reply With Quote
Old 02-03-2010, 08:21 PM   #6
OJ1988
Just a car guy
OJ1988's Avatar
Re: Z Bar
BTW, Grumpys is out of stock on the z bar though it is still listed on site.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 02-03-2010, 09:16 PM   #7
dan468
dan468's Avatar
Re: Z Bar
Anyone think of any reason as to why you wouldn't make your own frame and engine mount and put the Z bar where ever you want? You can adjust the rod to fine tune your throw correct?
68 C-10
Build thread
Old 02-04-2010, 08:41 PM   #8
OJ1988
Just a car guy
OJ1988's Avatar
Re: Z Bar
I guess if you had to, or wanted to move the engine back.
1973 Vega Drag Car
1970 C20 tow rig
Old 02-04-2010, 08:50 PM   #9
Tx Firefighter
Re: Z Bar
I've made several clutch linkages out of steel rod and aircraft heims ends. Just thread the ends of the rod and screw the ends onto it. Then you can adjust the length as appropriate.
Old 02-04-2010, 09:14 PM   #10
dan468
dan468's Avatar
Re: Z Bar
Heims? I like it. Do you have pics? BTW local 4361
68 C-10
Build thread
Old 02-04-2010, 09:20 PM   #11
Tx Firefighter
Re: Z Bar
I never took any pictures of them but the rod I get at my steel supplier. It's like 15 dollars for a 20 foot stick of 3/8 cold rolled rod. The heims I get from Summit or Speedway. Cut to length, run a die on each end for threads and assemble. Don't forget jam nuts.
