Old 02-02-2010, 02:20 AM   #1
jared87350
Camshaft ??????
i own a 87 R20 350.
I need to know the stock specs on the cam?
can i put a solid shaft in and out with the rollar ?
and what would be the greatest lift without stacking the springs?
thanks guys
jared87350 is offline   Reply With Quote
Old 02-02-2010, 06:50 PM   #2
jared87350
Re: Camshaft ??????
bumped. please help
Old 02-02-2010, 07:15 PM   #3
S10Fan
Old Heap Driver
Re: Camshaft ??????
I'd call Summit Racing's tech line. There's a lot of things to consider with a cam upgrade, carb/intake, gears, type of vehicle usage, etc etc.
If you're just looking for a rumpty rump sound you'll end up with a rough running motor that can't get out of it's own way. Been there done that.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 02-02-2010, 07:28 PM   #4
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
Re: Camshaft ??????
an '87 TBI 350 would not have had a roller cam shaft, it would have a hydraulic flat tappet. Check out http://www.tbichips.com/truckmods.htm He has a lot of good information on what your options are and what cams work well with TBI and what doesn't work.
Mike
Mr.Chevy4x4 is offline   Reply With Quote
Old 02-02-2010, 11:11 PM   #5
jared87350
Re: Camshaft ??????
i was wondering becouse comp cams has it in its own catergory as a roller
Old 02-02-2010, 11:17 PM   #6
Mr.Chevy4x4
Re: Camshaft ??????
87-95 TBI trucks had hydraulic flat tappet cams. It wasn't until the "vortec" motors that the trucks got roller cams.
Mike
Old 02-02-2010, 11:19 PM   #7
thehitchmaster
thehitchmaster's Avatar
Re: Camshaft ??????
ive always had good luck calling comp cams or whoever cam company you like. tell them what parts your using, and what your looking for. they can tell you exactly what to get.
http://www.gulftruckinc.com
thehitchmaster is offline   Reply With Quote
Old 02-02-2010, 11:21 PM   #8
jared87350
Re: Camshaft ??????
ok, awesome thanks for the info
Old 02-02-2010, 11:35 PM   #9
SMiller
Re: Camshaft ??????
Go with a Comp Cams Thumpr' cam, it is made for stock motors but has a lumpity idle, makes a little more power then stock but is best of both worlds. Check out youtube for vids.
SMiller is offline   Reply With Quote
Old 02-02-2010, 11:39 PM   #10
thehitchmaster
Re: Camshaft ??????
I do know that you have to be very careful with camshaft selection when using a T.B.I.
Old 02-03-2010, 02:33 AM   #11
jared87350
Re: Camshaft ??????
that sounds good
did some homework
i was thinking of 420 / 442 gross lift
and 262 / 272 Adv. Dur.
not to hot , but ......
please let me know what you guys think
Old 02-03-2010, 06:10 PM   #12
jared87350
Re: Camshaft ??????
bumped
Old 02-04-2010, 07:32 PM   #13
jared87350
Re: Camshaft ??????
bumped agian sorry
