02-02-2010, 03:31 AM | #1 |
drop kit or parts what is the best???
I want to drop my truck i want to do 4/4 or so i want to do it with a spindle and spring up front would like to do 3 inch spindle and 1 inch spring but may do a 2.5 spindle and 2 inch spring and shack/hanger out back i do not want to flip.
So can you guys tell me were to go for great stuff that will fit. I do not want to have a stay away story. thanks Jeff And a pic of my truck the red one and would like it to be as low as the blue truck sorry if it is a members truck but I like how it sits
1981 K-5 Blazer 2wd 1985 C-10 Short step 1988 C-10 Suburban |
02-02-2010, 03:41 AM | #2 |
Re: dorp kit or parts what is the best???
http://www.stylintrucks.com/sn.aspx?...sults_trigger=
i went with all the bell tech stuff. 3 inch spindles and the shackle and hanger kit. good quality parts, but expect to spend a whole weekend putting everything on though lol i have mine set to a 3/3 drop cuz i like a little rake but you could use the 3 inch spindles and just cut a half coil out of your factory springs. if i want to go a little lower that's what i'd probably do.
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
02-02-2010, 06:44 AM | #3 |
Yeah I wouldnt buy springs yet.. put the spindles on and see how low you are first and if you wanna go just alittle bit lower I would try cutting your springs thats what I did....but I got lowering leaf springs for rear and then I cut the front hangers off and moved them up the frame to get the height im wanted....I got my stuff from airbagit.com, Have had the spindles on for 6 years now and had the leafs on for 2 until I bagged it..
02-02-2010, 10:24 AM | #4 |
Insert Witty Text Here
Re: drop kit or parts what is the best???
To use 3" spindlles with those wheels, you'll have to do some grinding on the lower control arms. I have 2.5" spindles, and they clear my 8" rally wheels just fine.
I think that blue truck is lowered more than 4 inches in the back, probably with a flip kit. Slonaker |
02-02-2010, 11:14 AM | #5 |
What wheel size on the red truck! I MUST KNOW! AND BACK SPACING THANKS!
02-02-2010, 11:25 AM | #6 |
Next project: 1970 K10
Are those 15's on the blue truck? It's probably just me, but they look bigger than 15's. I love chrome Vette rallys, and they look great on that truck!!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 02-02-2010 at 11:25 AM. |
02-02-2010, 04:17 PM | #7 |
Well i want the tires about one inch from the top of the wheel wells so I think it will be ok with a 4/4 I love how Tony SS truck sits and that is what he did i think
Wheels grinding im not worried about im going to get a set of 15x6 car rallys for the front it will make the tires look and fit better Alex1 the fronts are 15x8 4.5 inch bs with a 26-8-15 tire and the rear is a 15x10 5 inch bs with 29-15-15 tire and some pics for you
1981 K-5 Blazer 2wd 1985 C-10 Short step 1988 C-10 Suburban Last edited by rigon4; 02-02-2010 at 04:21 PM. Reason: more info |
02-02-2010, 05:38 PM | #8 | ||
02-02-2010, 05:56 PM | #9 | |
Thanks, I appreciate it! |
02-02-2010, 06:36 PM | #10 | |
The One And Only !!!
Rigon4, How much space (inches) do you have between the tires (side wall) and the leaf springs with that set up ? Thanks
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
02-02-2010, 07:33 PM | #11 |
Restrorob the tires are flush with the body on the out side a 1/4 inch from the box floor on the inside and 2 inches give or take from the leaf spring.
When the truck is going in for paint im going to tub it by cutting down 67-72 bed wheel tubs and taking it to the frame rail in prep for a for link set up some day inside the frame rails for max wheel and tire room
02-02-2010, 10:43 PM | #12 |
keep in mind what slonaker said. if your going to run 15's with 3" spindles.
http://www.gulftruckinc.com |
02-02-2010, 11:04 PM | #13 |
Badass
i put 3in drop spindles and didnt grind any from the lca.only some from the arm holing the caliper and the top of the caliper a little.
and yes its on stock 15x8 rallys
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
02-02-2010, 11:14 PM | #14 |
my rallys hit the control arms near the lower ball joint and also the control arm itself when I turned. hope im not jackin up the thread.
02-02-2010, 11:40 PM | #15 |
67-72 parts collector,…
02-02-2010, 11:48 PM | #16 |
thats what i ended up doing. I just didnt want any surprises for him when installing his kit. A grinder and a torch can fix anything lol.
02-03-2010, 12:31 PM | #17 |
ttt any other brands that are good
02-03-2010, 12:48 PM | #18 |
like i just posted on that other thread, i personally like western chassis stuff for quality and fit/finish ....sport truck direct sells there brand
1987 350 TBI lowered 5/7 |
