Fat man fab ifs
Are the ifs kits from fat man fab any good it says bolts on can run coilovers,bags,shockwaves drop front end 6inches with ground clearence issues,polished a arms.Wassup with it?
Flowershop Hip Hop & Street Rods Dropmember 83 Custom Deluxe Almond on Almond 85 Silverado White on Red/Now Chevy LeMans Blue Rendering in Truckin magazine vol 36 no. 11,2010 |
Re: Fat man fab ifs
I'd drop w/stock truck stuff or a Dropmember before I'd consider a Fatmans bolt-in kit for these trucks.
Re: Fat man fab ifs
I was just wondering what's to it I never hear about them but for the older classics.
#4 | |
Re: Fat man fab ifs
They utilize smaller brakes than what 71-87 trucks came w/from the factory (which require different rotors & calipers). They require MII specific a-arms (stamped or tubular). The main benefit of these over OE components is they give you slightly more clearance @ the same 6" drop vs. OE c.member & arms.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-02-2010 at 10:46 AM. |
Re: Fat man fab ifs
Fatman fab uses mustang 2 parts it will handle worse and probably ride like crap too.The reason the older car people love them is its a cheap easy way to remove a straight axle.They get a ifs front disc and rack and pinion cheap.It is a upgrade from a straight axle,But a newer truck like yours its kinda a dumb idea.You can get a dropmember and a everything needed for not much more it will ride better and not mess up your steering and suspension geometry.
Re: Fat man fab ifs
Most MII set-up's are engineered so the steering & geometry should be as good as a MII set-up goes (some even better).
I think they have their place. But, vs. an updated 71 & up GM truck suspension/brakes, I don't think they're worth it unless that extra ground clearance is worth the extra expense of having to get different control arms, spindles, calipers, & rotors. If you have the money, the PB Dropmember or similar is the better direction.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-03-2010 at 01:20 PM. |
Re: Fat man fab ifs
Had a nice long conversation with Nathan yesterday.
Re: Fat man fab ifs
Your looking for a coilover setup correct? You don't want bags?
Are there any other options out there for someone that doesn't want bags?
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= ![]() Douchebag Racing: Runs Fine all the Time |
Re: Fat man fab ifs
Have not really mad up my mind so we talked about different options. He a lot of help and a real cool dude he reached out to me to try and help me out. Cheese been talking to me about two trucks I like that were done over at Hills. Been talking to Jeff also.
Re: Fat man fab ifs
Think you can run coilovers on one of the dropmembers.
Re: Fat man fab ifs
i have bought a truck and he had already had purchased the kit so i have started to put it on my 72 c10 step side. i do have 16 inch disc brakes and seem to be going on just fine. engine mounts are tubular and are getting installed on 9 of july and will have pics for you.
#12 | |
Re: Fat man fab ifs
Any more picts? It's always good to see all the options.
Doug Looking for a 67-72 short bed driver..... |
#13 |
Re: Fat man fab ifs
here is a pic of our coil over front with the optional splined sway bar we are running a forum special at the moment which is a killer promotion. Let me know if you have any questions
