Old 02-02-2010, 03:27 PM   #1
creep
Registered Loser
creep's Avatar
Rear Cab Mounts?
Are the rear cab mounts on a 63 3/4 ton interchangeable with 1/2 ton mounts? I know the brackets are different but can they be swapped and still line up?
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 02-02-2010, 09:50 PM   #2
Ham-er
Re: Rear Cab Mounts?
Does this help?
http://persh.org/pickup/c20_cab_mounts.htm
Ham-er is offline   Reply With Quote
Old 02-02-2010, 10:08 PM   #3
GMCMG
GMCMG's Avatar
This is correct. I have a 3/4 ton frame I'm putting 1/2 ton mounts on. Just ordered a set from LILRED66 (Tony). Just grind off the rivets and bolt the other mount in place. Everything lines up.
GMCMG
1964 GMC 1/2 ton LWB project
- 1982 GMC 6.2 diesel engine/suspension donor
- 1966 Chevy 3/4 ton frame/doors/fenders donor
- tons of parts - cause you can't build a truck without 4 of everything!
2001 3/4HD Duramax Diesel extended cab lwb4x4
1984 Chevy C30 6.2 diesel lift truck (project)
1962 GMC w/5 lugs, 350/350 auto (was for parts, but couldn't bring myself to do it!)
glascock.m@hotmail.com
GMCMG is offline   Reply With Quote
Old 02-03-2010, 03:48 PM   #4
creep
Registered Loser
creep's Avatar
Cool, thanks.
Old 08-17-2011, 09:22 PM   #5
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Originally Posted by Ham-er View Post
Thanks for the link.
Does anyone know what was the theory behind the C20 Shear Type Mounts?
66 C20 Service Truck:
Old 08-17-2011, 11:24 PM   #6
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I think it was to provide a softer ride, they seem to have quite a bit more give than the 1/2 ton mounts...
Old 08-18-2011, 12:01 AM   #7
LostMy65
LostMy65's Avatar
That's what I was thinking.
The 3/4 ton is obviously a jerkier ride.
Old 08-18-2011, 02:30 AM   #8
padresag
it was used to give more of a floating action to any of that style cab above a c20 due to the more rigid suspension
padresag is offline   Reply With Quote
