Old 02-02-2010, 06:46 PM   #1
culp7
HickTown
culp7's Avatar
New to 47-54's...HELP!
Ok, so I have always been into 67-72 chevys but I think I will begin my venture into uncharted territory...47-54 Chevy trucks!!!
But before I buy my 1st one I have a few questions I would like adressed:
1. I would like to drop the motor and tranny onto a S10 4x4 frame... what are the years and models of S10's i need to look for??? (extended cab, ect.)
2. How does the oiling system work on these trucks?
3. I am pretty sure they came out with automatic trannys in this period, if so, what year did they come out, and how rare are they?
Thanks, Bryant
1993 Ford Mustang Vert w/ 2.3
1969 Chevy C/10 w/350
1968 Chevy C-20 w/250
1976 Dodge Aspen W/ 225
2000 Toyota Tundra w/4.7
1987 Dodge Ram D-100 w/360
255/70-15
___________
(oo)══╬══(oo)
culp7 is offline   Reply With Quote
Old 02-02-2010, 07:00 PM   #2
sgtusmc
sgtusmc's Avatar
Re: New to 47-54's...HELP!
I might be of some help as far as the s10 goes. Years to look for on s10's are 1982-2004. There are very few changes to the frames. The easiest frames are the standard cab long bed (wheel base is 1 inch longer than the AD base.) Extended cabs will also work with cutting the wheel base down.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 02-02-2010, 07:36 PM   #3
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
The 216's had what would be a low pressure system in them; I think 15 psi. Then with the 235 it had a full pressure system 30psi. They were both pretty basic, but I do believe similar to what we still use today. I'm not 100% on these numbers.
There were automatics available for these trucks. I believe that they were first offered in 53 or 54. They were hydromatic 3 speed. I have seen them around cheep, but they can get expensive. You just need to keep an eye out for 'em.
Hope this helps ya.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 02-03-2010, 01:10 AM   #4
Steve@OldSub.com
Cancer Survivor in the making.
Steve@OldSub.com's Avatar
GMC actually offered the Hyrda-Matic in PM series trucks in '52 but they are rare and I have never seen one. GMC offered the Hydra-Matic in pickups in '53 and Chevrolet followed in '54.
I own a '54 GMC with Hydra-Matic and I have a buddy with a '54 Chevy Hyrdra-Matic. And hyphenated with both caps is how its spelled out on the emblems on my GMC.
The Hydra-Matic is a 4-speed automatic that has no torque converter.
Frankly if you want to drive your truck much and want to use an original type motor I'd recommend buying an adapter and using a more modern transmission. Its likely to be cheaper than rebuilding the Hydra-Matic and you'll be happier with the way it drives.
Steve@OldSub.com is offline   Reply With Quote
Old 02-03-2010, 01:19 AM   #5
nickp51chevy
I was close I guess.
I didn't know they were 4 speeds. I thought they were 3 speeds. Good to know.
Had;
Old 02-04-2010, 10:54 AM   #6
Muleman100
Muleman100's Avatar
I agree with Steve, the later model trannys are cheaper to rebuild. I have a 1954 GMC and a 57 Chev pickup both with factory Hydra-Matic trannys. They are defintely a different animal, but rare.
Muleman100 is offline   Reply With Quote
Old 02-07-2010, 12:34 PM   #7
49ZR2
49ZR2's Avatar
Building mine on a 2000 ZR2
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=372267
49 4x4 build
51 Willys frame off beer getter.
49ZR2 is offline   Reply With Quote
