02-02-2010, 07:18 PM | #1 |
Auto Tranny Cross-member (member? you member!)
I have 2 auto transmission crossmembers for our trucks. as you know these are needed when converting to an auto tranny. One has all 4 mount, locations and one has the upper mounts removed, (probably to run exhust )
40.00 for the one pictured and 30 for the other (with the upper mounts) both are very solid. out of NM trucks no rust!!! plus the ride
1967custom Last edited by michael bustamante; 02-02-2010 at 07:20 PM. Reason: add on |
02-02-2010, 09:33 PM | #2 |
Re: Auto Tranny Cross-member (member? you member!)
A little new to this but are the cross members not the same (TH350 to SM465)? I thought they just used different tranny mounts. I am looking in to some swapping.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
02-03-2010, 03:58 PM | #3 |
no they are different and they are in different locations on the frame. the manual tranny ones sit right behind and under the firewall while the auto tranny ones that I have sit under the cab, like under the bench seat more or less, the manual traany have a mount on either side of the tranny while the auto tranny have one mount in the center rear of the trans
1967custom |
02-03-2010, 06:34 PM | #4 |
how much shipped to 39402 ?
02-03-2010, 06:58 PM | #5 |
which one are you needing? the one in the picture or the one with the 2 additional arms rivited on. (great for trucks with alot of torque but get in the way of some custom exhaust systems) 15 dollars for the one in the pic. 22 for the other
1967custom |
02-03-2010, 07:26 PM | #6 |
I have a 68 1/2 ton 4WD Suburban that currently has a manual 4 speed transmission
in it and I will be converting it to an automatic very soon. Which ever cross member you have that will work for that application, if either one will work, I will take it so just PM me the details if either one will work.... |
02-03-2010, 07:33 PM | #7 |
unless youre running a big block the one in the pic will be good, Ill pm you the info
1967custom |
02-04-2010, 12:50 AM | #8 |
Just like to part out trucks!!
As far as I know, 4x4 are different than 2wds. 4 speed and automatic crossmembers are the same in 4x4's. The lower bracket on 4x4 is deeper. No difference between 2wd bb and sb.
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" Last edited by teeitup; 02-04-2010 at 01:03 AM. |
02-04-2010, 11:25 AM | #9 |
Ive never seen a 4wd tranny crossmember. yeah I guess that would be a big difference. These are from 2wd trucks. Sorry about that
1967custom |
02-04-2010, 06:53 PM | #10 |
if that is the case I don't need it then, thanks for the information teeitup !!!!!
I am a bit green at the mechanics of the manual to auto swap but have read several threads on the forum.... |
02-04-2010, 06:54 PM | #11 |
its a good thing we found that out. thanks teeitup. you saved me some embarressment
1967custom |
02-04-2010, 11:21 PM | #12 |
No problem guys, just glad to help out. Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
02-07-2010, 09:15 AM | #13 |
I need help men:
I want to use an new aluminum Bell housing without the lower mount bolts in my 71 C10 Shortbed 3 speed /350ci. My truck frame has no provision right now for a mount to the tail of the transmission. Originally it had a steel bell with 2 tapped mount flanges up front and only rear support from the center carrier bearing of the 2 pc drive shaft. Can I use one of these?
Parts? |
02-08-2010, 01:28 PM | #14 |
no I dont think this would work for you, if you fab it to mount the rear of the manual tranny I would think that you angle would be all wrong. sorry man, now if youre converting to a auto tranny than this is whatg you need but you will have to remove the manual tranny crossmember
1967custom |
02-10-2010, 04:46 PM | #15 | |
I have a 454 with a muncie 4speed in my 70 2wd blazer with a 2wd auto crossmember...No mods at all...If your 3 speed has a trans mount location...some do..it will work..I have done that before
02-10-2010, 07:16 PM | #16 |
if your 3 speed has that mount that hes talking about, let me know and ill set you up
1967custom |
02-17-2010, 02:12 PM | #17 |
I know this is an old post but I sure do need a transmission cross member. I have no idea really what I need. I have a 72 stepside GMC that originally had a straight six in it with a 3 speed manual transmission...column shift. The PO converted to a Turbo 350 Auto Transmission (I think...) and used some ugly half assed crossmember that barely spans the width of the frame. I would like a nice clean crossmember.
So would one of your crossmembers work for my application? If so shipping to 39114? And lastly, I'm financially embarrassed right now and have commitments for my only spare $100.00 for a bumper I'm buying next weekend. If this will work could you possibly wait a couple weeks till March 5?
Baby John & Tyler Shows My son and I are resto-rodding a '72 GMC Stepside |
02-17-2010, 03:09 PM | #18 |
if your truck is a 2wd it is the one you need, (factory) your frame will have the bolt holes already, pm me and Ill give you my pay pal or my address.
Thanks man!! oh and march is fine, Ill ship it out as soon as I hear from you, 50.00 shipped, better yet, 45.00
1967custom Last edited by michael bustamante; 02-17-2010 at 03:12 PM. Reason: lowered price |
02-17-2010, 03:52 PM | #19 | |
Thanks...done deal then. Let me buy the bumper next weekend, and then I'll get with you on your address and I'll mail you a check. I had a pay pal account a long time ago but I've changed companies, and email addresses since then and I basically just haven't gone through the trouble of setting up another account.
02-17-2010, 04:07 PM | #20 |
BlahBlahBlah
Title to this thread cracked me up...I member=)
… … … … … … … … ... … … … … … … … … … … … Last edited by CG; 02-17-2010 at 04:08 PM. |
02-17-2010, 05:53 PM | #21 |
boy I hope youre not the only one that got that!! I like watching the new George Lopez nite show
1967custom |
02-17-2010, 09:13 PM | #22 |
BlahBlahBlah
I went to post a youtube of it in my thread, but there was some mild cursing in there. We try to keep it family friendly round here...I havent seen his show, I just hear him on my sirius radio in my car.
Ok, back to the regularly scheduled truck thread lol
02-18-2010, 11:24 AM | #23 |
I am the guy with the 3 speed Saginaw tranny that I need to incorporate a rear tail housing transmission mount. I changed the stock steel bell housing over to an 11" alum, but the alum has no bolt up provision in the bottom of it like the stock had.
My tranny has a two hole threaded mount pad on the bttm of the rear of the tail housing under the local where the drive shaft yoke slides in. I am considering buying a universal cross member from ClassicParts for a 50's era Chev Trucks because it is only 50$. I could then cut/weld/mod to make it fit.
Parts? |
02-18-2010, 01:07 PM | #24 | |
1967custom Last edited by michael bustamante; 02-18-2010 at 01:08 PM. |
03-21-2010, 03:13 PM | #25 |
Its Topless Season!!!!
PM sent
