Addicted to Rust
![]() Join Date: Dec 2009
Control arm hijinks
I need some more camber. I am 1\2 inch in (negative) at the top from 0 caster. It already has 1 1\8 of shims in the upper arms. So need to move the top of the spindle out 1 5\8 to get to 0 camber. So I am going to have to modify the control arms. I am going to leave1\4 inch for shims to adjust the caster. What is the oe camber spec? It should be slightly negative. I am concerned that an upper that long will put the tire into the outer fender lip. So a shorter lower/longer upper may be more practical. Any thoughts or comments? Jay
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
Old Heap Driver
Re: Control arm hijinks
One of these may help..................
Moog Control Arm Shaft Kit Part No. K6184 This shaft adds camber to reduce the number of shims needed.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. Last edited by S10Fan; 02-02-2010 at 11:35 PM. |
its just $$$$$
I had the same problem with my crew cab short bed
resident wrencher
ya my trucks the same way its got like 2 and a hlaf inces of shims whats the best way to fix this i still need a few more shims to make it in spec
TUKE-NoBullChit Customs owner
wow, this reminds me of my 79 blazer i drove back in high school. i hacked at least 2 coils off the front, cut off the bumpstop mounts, added tractionbar bumpstops, then even with it spaced all the way out it was still way off. i ended up going to the bolt supply and grabbing grade 8 fine thread bolts that were longer than the oem upper a-arm studs. i put those in place and took 1" pieces of pipe and welded washers on the ends to make spacers to put in. worked out pretty well. only bad thing was you have to hold the bolts on the inside and they arent that easy to get to, think i used a socket on a breaker bar to hold them.
was the lowest thing around, i flipped the rear and took out 2 leafs in the back, wish i had a pic, them cragar ss mags looked good, 15x10 in back and 14x8 reverse up front. woulda loved to know they had offset upper shafts |
#6 | |
At the body shop.
" That didnt make it any newer " " Dont antique the equipment " |
GM Addicted
how hard are they to knock out my dad wants me to do that to my truck so my alignment can be better
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
At the body shop.
BFH i did mine. Im in tulare if want to see
GM Addicted
What where you stay at in tulare thats where my dad is from he grew up there. Im in sacramento right now ill be back in town the 19th of march.
its not that hard,this is the same as i did
