Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-03-2010, 01:19 AM   #1
cweber
What could I expect?
Im building a 350 for my 84 Chevy, and Im wondering if anyone could tell about how much hp I could expect. Im running vortech heads ported and polished, gm performance intake, roller rockers and cam, specs are 288/308, Lift .431/.451, edelbrock 600 carb, and longtube headers. It will be a huge upgrade from the sick 305 thats in it, i hope. Thanks
cweber is offline   Reply With Quote
Old 02-03-2010, 03:30 AM   #2
Blackbird66
Re: What could I expect?
350 HO crate motor is similiar and makes 330hp. I'd guess between 300-350, probably closer to 300.
May not sound like much, but you should feel a real improvment.
Blackbird66 is offline   Reply With Quote
Old 02-03-2010, 09:50 AM   #3
cweber
Thats about what I thought. This is my first toy so Im not sure what to expect. It has a 700R4 and I am planning on 3.90 or 4.10 gears. You think it will have enough to be a "street machine" or just a tire burner?
Old 02-03-2010, 05:54 PM   #4
Blackbird66
I think a 3.9 or 4.10 is a lot of gear for a motor that won't need to spin more than 5 grand. 700r4 has a steep low gear. I have a 3.73, and five speed with 275/60 15 back tire.
Performance is relative. I think anything with four wheels is slow. For around 10k you can have a bike that will run 9.x 1/4 , top out around 185, get 40+ mpg, and have a full warranty.
That said, I think you have potential for a fun ride.
Old 02-03-2010, 09:18 PM   #5
cweber
I have no desire to go much faster than 100mph. Im more into 0-60, if i can get close to 5.5 seconds that would be awesome but i dont think it will happen. My buddy has a 350Z and I want to at least hang with him for a while. So would you suggest 3.73 rearend instead?
I mainly want somthing that will turn some heads, sound good, and get up and go a bit.
Old 02-03-2010, 10:08 PM   #6
Blackbird66
yes 3.73 or 3.55
hang with a 350z? dunno
350z has more hp, but less torque
better traction
less weight
better weight distribution
good luck
Old 02-04-2010, 04:09 PM   #7
team39763
Well, you'll definately need some sticky tires...if you sit there spinning, it's over for you.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 02-05-2010, 12:29 AM   #8
cweber
True. Tires will be coming soon.
I have been reading on the GM 330 horse motor and the advantages i have over that one is all roller valve train and port and polish heads. How much extra horse is that good for? I think I may be closer to 350, but I dont know. I would like to put it on a dyno just for my own research.
I think I have decided on going with a 3.73, plus I thinik a friend has one in his garage.
I only have 3 more valves to put in to finish the motor. We will finish that tommorrow and pull the junkie 305 out, Saturday put the new one in. Im excited, not to mention driving around with open headers till Sunday when I rebuild the exhaust.
Old 02-05-2010, 01:51 AM   #9
ripdog28
ripdog28's Avatar
The 330 hp motor is tested and tuned by GM RnD. Your motor if put together without all the testing. Port and Polishing can sometimes hurt performance. Also the 330 hp motor has new casting heads. How old are yours? the 1st gen Vortech were good (also cracked after a while) but the newer ones are better. There isnt much diffrence but it is a diffrence in the casting/chamber. IMO, your probly close to 330hp, 350 is not out of the question. maby 380tq.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 02-05-2010, 09:46 AM   #10
cweber
Ok thanks. Mine are probably older ones. I believe they came off a 98 model.
Old 02-05-2010, 09:56 AM   #11
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
well then theres always just DO NOT TELL ANYONE..then learn when to use it!!
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 02-05-2010, 01:01 PM   #12
cweber
A stock bottom end can hold a small shot cant it? Somthing like a 50-100? And not blow up of coarse.
Old 02-05-2010, 06:56 PM   #13
Hottrucks
Hottrucks's Avatar
if the botttom is in decent shape and you dont hold it to long.....
Old 02-06-2010, 01:18 AM   #14
cweber
I doubt nitrous will be anytime soon. We got the old one pulled out tonight. Tommorrow, swap accessories, clean engine bay, and drop in new motor. Im pumped!
Old 02-06-2010, 12:29 PM   #15
djracer
djracer's Avatar
Sweet. Their is a lot of power in tweaking and tuning.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 02-07-2010, 04:34 AM   #16
cweber
The motor is in, and i couldnt be happier! I got to do a little open header action, and even got my exhaust done as well. Now to just take her easy for a little while and start tuning next week. You can tell its not quite stock, has a nice aggressive tone. Im going to bed 6:30am - 2:30am is to long to be up.
Old 02-07-2010, 04:57 AM   #17
Super73
Super73's Avatar
Personally, I like a steeper gear with a taller tire..
Examples, all things being equal, 7% verter slip, 3rd gear and 6k rpm:
26" tall tire with 3.73 = 116mph
27" tall tire with 3.90 = 115mph
28" tall tire with 3.90 = 119mph
28" tall tire with 4.10 = 113mph
30" tall tire with 4.30 = 116mph
A couple things to think about for the taller tire steeper gear.
A taller tire has more roll out allowing it to last longer than a shorter tire.
A taller tire has more contact patch, allowing you to hook better.
A taller tire has more sidewall, again can be an aid in hooking on the initial hit.
If it were me, I'd go 4.30 with a 30" tire over a 26" tire with 3.73's..
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 02-07-2010, 09:36 AM   #18
djracer
djracer's Avatar
Congrats good luck finding a few more ponies when you get to tuning on it.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-07-2010, 12:16 PM   #19
cweber
Thanks, I dont think its going to be a drag truck, but definatly plenty to play with.
Super73- thanks for the info, I think I will go for the taller of my choices on tires.
Old 02-11-2010, 11:06 AM   #20
dan42
dan42's Avatar
Sounds like it's going to be a great ride. Once it gets running, you'll need to get get used to driving it, eh? Just hold on loosely, and don't let her go...
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 02-11-2010, 04:56 PM   #21
cweber
LOL
I think I have some carb troubles, i used the edelbrock 1406 from the 305. If you romp it it falls on its face, up until yesterday i havnt been gettin on it hard. I think there may be some trash in it or something. My buddy wants to build a holley for it.
