Old 02-03-2010, 02:15 AM   #1
OregonC20
OregonC20's Avatar
1991 3/4 ton Chevy wheel, will it fit?
Does anybody know if these wheels will fit on a 1970 Chevy 3/4 ton? I have drums at front and back.
Thanks.
OregonC20 is offline   Reply With Quote
Old 02-03-2010, 03:09 AM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: 1991 3/4 ton Chevy wheel, will it fit?
Yes, you'll need new lug nuts though. The 1991 truck has metric lugs.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 02-03-2010, 03:26 AM   #3
harry
harry's Avatar
is the wheel offset the same ??
harry is offline   Reply With Quote
Old 02-03-2010, 04:57 AM   #4
Sublvr72
Sublvr72's Avatar
yes those will fit, my friends dad had those on his 69 for years
Sublvr72 is offline   Reply With Quote
Old 02-03-2010, 09:19 AM   #5
LAW51
I have them on my 67 Chevy. As previously stated, you will need to replace the lugnuts to get the caps to attach. The stud size is different on the 67 from later models. So you have to get the right size lugnuts. I bought mine on ebay, but you can also get them from a parts supply store.
LAW51 is offline   Reply With Quote
Old 02-03-2010, 05:42 PM   #6
OregonC20
OregonC20's Avatar
Thanks everyone! does anybody have a picture of these wheels on their 67-72 truck?
Thank again.
Old 02-03-2010, 06:22 PM   #7
capev86
the 71-72 3/4 ton should have a newer style lug (thread size) than the earlier trucks, right?
capev86 is offline   Reply With Quote
Old 02-03-2010, 07:45 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
67 - 70 trucks had 1/2 inch studs.
71 - 80-something had 9/16 inch studs
then it went to metric, probably a 15 mm, but that size is pure speculation.
Old 02-03-2010, 08:13 PM   #9
Mike C
Mike C's Avatar
14mm. 88 and later on the "new" body style trucks. Not sure on the "old" body style trucks through 91. My 86 dually has 9/16 lugs. The other posters are correct that the 70 and earlier has 1/2" lugs.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-03-2010, 08:57 PM   #10
ironhill
ironhill's Avatar
Heres a couple pics of my beater 72 GMC K20 with the wheels on it. I had to get dually centers to clear the rear hub and machined the fronts out for the 4x4 hubs but used the regular 3/4 ton center caps on the front
ironhill is offline   Reply With Quote
Old 02-04-2010, 01:33 PM   #11
bignbad
bignbad's Avatar
why would you have to get differnt lug nuts?The wheel studs arnt part of the wheel/rim.The studs are part of the brake drums.I can see getting acron or mag or even longer or shorter style ones.Thread size you shouldn't have to change.3/4 ton trucks ford,chevy,and dodge the rims all interchange.You might have to modify the hub part of the rim.
'72 chevy k20
'06 H-D Springer softail
http://www.bluemooncruisers.com/
http://www.enginecycle.com/
~Eric
bignbad is offline   Reply With Quote
Old 02-04-2010, 07:19 PM   #12
ironhill
ironhill's Avatar
You have to get the special lug nuts because they have external threads for the black plastic covers to screw onto to hold the center in thats all that hold the center in place without the special external threaded lugnuts you can't install the center
