Old 02-03-2010, 07:48 AM   #1
silvervic99stang
silvervic99stang's Avatar
installing front bags
I'm also all new to the air ride suspension i have purchased a 84 chevy to switch front crossmember and 5 lug set up to my 66.. i purchased from ***************** a 63-87 Chevy C10 Front Bag & Bracket Kit... i dont understand the cup on it i figured that the bag would just sit in the lower control arm... does anyone have detailed instructions to install air bags for us new guys and pictures thanks..
silvervic99stang is offline   Reply With Quote
Old 02-03-2010, 09:49 AM   #2
jmedero
jmedero's Avatar
Re: installing front bags
The cup gets bolted to the bottom of the bad and just sitts in the lca spring pocket.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 02-03-2010, 03:17 PM   #3
aggie91
I'm just glad to be here!
aggie91's Avatar
Thats correct. The pocket in the lower a-arm is not big enough for the bag not to rub if just set in the lower arm. Bolt the cup to the bottom of the bag so that the bag is raised up out of the spring pocket in the lower arm.
I will see if I can find a picture.
Look at post #44 in this thread. It shows the cup sitting in the lower arm.
http://67-72chevytrucks.com/vboard/s...=377272&page=2
Also in the same thread, post #96 photo's 4 & 5 show the bag assy with the brackets and plates from suicide doors.
hope this helps...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-03-2010, 06:13 PM   #4
silvervic99stang
thanks man that is some good info....
