Old 02-03-2010, 07:59 AM   #1
HeavyChevy87
Anyone have pics of reverse hood hinges?
I'm thinking of reversing the hinges on my project truck.
HeavyChevy87 is offline   Reply With Quote
Old 02-03-2010, 08:10 AM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Anyone have pics of reverse hood hinges?
use your seach this has been talked about quite a few times ..heres the short version...
bad idea dont do it
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 02-03-2010, 08:16 AM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
I've got that type set-up on my 97, Had the same set-up on my 74 before I stripped it for restore.
Had a gust of wind catch my glass hood and stand it straight up off the prop rod during a show and put the cowl scoop through the windshield, I took the hinge set-up for the 74 and put it in the 97.
The hinge assembly is out of a 89 Buick Park Avenue, You also need the cowl gliders off the Buick as well for a easier install on a square body.
I have pics someplace of the re-worked gliders/brackets etc. but have to get to work now, Will post later if your interested.....
bad idea dont do it
Hmmm...... And why not ???
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-03-2010, 08:20 AM   #4
HeavyChevy87
I have pics someplace of the re-worked gliders/brackets etc. someplace but have to get to work now, Will post later if your interested.....
Really interested. The main reason I'm wanting to do it is because of a 4 inch cowl.
Old 02-03-2010, 09:00 AM   #5
Hottrucks
Hottrucks's Avatar
it makes it difficult to do anything under the hood....it looks kool ...but not worth it to me ..I used the BMW hood stuff on and old truc I had...and like he said the wind got ahold of it and??????????????
Old 02-03-2010, 11:12 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
use your seach this has been talked about quite a few times ...
If this is the best advice you have to offer, please don't bother to reply.....bad idea dont do it
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-03-2010, 12:28 PM   #7
suville
suville's Avatar
In the FAQ section there is a post about this mod , it was done by Lewis Fab "Rocrin" I believe.
suville is offline   Reply With Quote
Old 02-03-2010, 01:12 PM   #8
Mr.Scary
Project Optimus Prime
Mr.Scary's Avatar
looks to be a pretty cool mod but it looks like you might have a problem reaching a few areas under the hood so i might think twice about it, but go for it if you like it!!!
84 SWB work in progress
89 burb 1500 (parts pig) LOL
08 ford focus (I know, I know) Wifes car
"I said it b4 and i'll say it agian wiring is my worst enemy":devil:
Mr.Scary is offline   Reply With Quote
Old 02-03-2010, 01:27 PM   #9
Restrorob
Restrorob's Avatar
He said (Me) "The wind got under the hood with the OLD prop rod"......
I have been to another show at the same location (a open air port taxi strip) with this set up and the hood didn't budge.
What kind of truck did you do this to ? And, I'm sure the BMW set-up was different.....
I was constantly bumping my head and elbows on my hood while working near the back of the engine bay, No more..... Every things wide open to get to with less bending over. The hood isn't in the way of working on the front of the engine either, I just stripped all accessory's and brackets for re-paint/detail.
I performed this mod to my trucks because I wanted something different that nobody in my region and not many on this board have done, And.... Because IMO it's a cool mod.
That's my story and I'm sticking to it !
More pics later, Lunch time is over.....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 02-03-2010, 07:48 PM   #10
thrtsxchambers
thrtsxchambers's Avatar
I have heard those parts would work. I found a local jyard that has them but have not been up there to check on what I may need. Would you happen to have pictures of the parts you had to get and any advice on the install. I am doing the flip hood after I finish my suicide doors. If you want just pm the info so I'm not trying to jack the thread unless heavycheavy87 wants it too.
thrtsxchambers is offline   Reply With Quote
Old 02-03-2010, 10:38 PM   #11
Restrorob
Restrorob's Avatar
PM's Sent.....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 02-04-2010, 01:27 AM   #12
westofb
I really hate wet sanding!
westofb's Avatar
I want to see someone use the buick hinges to have the hood raise sideways and being in the up position over one of the front tires!
Jeff,
68 C-10
75 C-20, now a C-10!
10 F-150
westofb is offline   Reply With Quote
Old 02-04-2010, 07:13 AM   #13
Restrorob
Restrorob's Avatar
Post up pics when you get it set up !
I'm out of trucks to try it on.....
BTW, There's more room on the driver's side for the hinge assembly....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
