Old 02-03-2010, 09:52 AM   #1
6t727t2
Active Member
'72 door panels
This pair has no extra screw holes, chips or deep scratches. They are original dark olive, poorly painted black. Chrome rings look good. Aluminum inserts have no dents, they have stick on woodgrain shelf paper which look good with your eyes closed. These are good pcs to restore. $75 shipped for the pair
6t727t2 is offline   Reply With Quote
Old 02-03-2010, 02:51 PM   #2
Re: '72 door panels
Harry,you cracked me up with that eyes closed comment....Now that`s an honest description right there!
Old 02-03-2010, 07:58 PM   #3
6t727t2
Active Member
Re: '72 door panels
Tim, my first description said they looked good to Stevie Wonder, but I edited that.
Old 02-04-2010, 01:56 PM   #4
BossHogg69
motor exploder
BossHogg69's Avatar
Re: '72 door panels
here's a bump for the humor
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 02-06-2010, 08:17 AM   #5
WIDESIDE72
WIDESIDE72's Avatar
Re: '72 door panels
I wonder if the black paint will come off with something like lacquer thinner without ruining the plastic... Are there any cracks or defects in the plastic panels themselves?
WIDESIDE72 is offline   Reply With Quote
Old 02-06-2010, 08:54 AM   #6
6t727t2
Active Member
Re: '72 door panels
WIDESIDE72, I guess it depends on what type of paint was used as far as removing it, dosen't look like any primer was used, and a lot of the paint has already worn off. No cracks or damage to either panel, and they are straight.
Old 02-06-2010, 12:55 PM   #7
72highlander
Sophomore Member
72highlander's Avatar
Re: '72 door panels
If they are solid with good grain, green is one of the better colors for not chalking out. They can be bead blasted and dyed your color easily.
1972 Chevrolet Highlander SWB
1972 Custom Deluxe 3/4 2WD 60k miles
these trucks don't need vacuum gauges cause they don't suck!
two wrongs don't make a right, but three rights do make a left
all i want is a little more than i'll ever get
it's better to be judged by 12 than to be carried by 6
72highlander is offline   Reply With Quote
Old 02-06-2010, 01:28 PM   #8
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: '72 door panels
For the record, I had to strip some old dye off a pair of 87' door panels for my father's K30 and it came off with some elbow grease and lacquer thinner. It does not damage the plastic. If wanting them green again, just use laquer thinner on them with a rag and then afterwards use a light duty scrub brush and thinner. Then polish up with interior shine. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
