02-03-2010, 01:09 PM | #1 |
4WD Conversion
Has anyone done a 4x4 conversion on their 2WD square body and if so what is entailed? Are there any tutorials on this? Would a Suburban frame work on a full bed pickup?
02-03-2010, 01:52 PM | #2 |
Re: 4WD Conversion
a frame swap is in order. I would just look for a the correct frame, if you have a lwb truck, just look for a lwb frame or a complete truck, and then swap your body. Its best to stay in your year range, if your truck is a 73-80, get a 83-80 frame and the same for 81-87.
I am doing a 2wd to 4wd frame swap in here: http://67-72chevytrucks.com/vboard/s...d.php?t=383629 |
02-03-2010, 03:58 PM | #3 |
Re: 4WD Conversion
the REAL problem is that the crossmembers need to be changed and since the 2wd frame is different than the 4wd frame you just cant swap crossmembers i think. This is whats stopping me from doing the swap. to my 1 ton.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
